Question about Whirlpool Duet GHW9150P Front Load Washer
My kenmore he frnt load washer has an error code of (f24). tried the manual solution no luck. can you help me?
  • 8,197 Answers
On this model of HE washer, the F24 code indicates that the water temperature sensor is out of range (23 degrees to 217 degrees F). This usually indicates a bad thermistor (temperature sensor - Key 24 in the image below). A bad wiring connection or a failed control board could also cause this problem.
Good luck
Posted on Oct 05, 2009
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
We are seeing F24 for the first time today on our Kenmore HE2plus front loading washer. What does it mean? How do I solve it?
Hi
F24 is a water temperature sensor error. You have to unplug the washer and check the water temperature sensor and its connections, if that is fine then check the resistance of the heating element and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore He 2 plus washing machine, which is getting an error code (F24). Can someone help. I'm not sure if this is an easy fix or not, nor what needs to be done to stop this error. Thanks
Hi
Daniel
Aug 07, 2011 | Kenmore 3.2 cu. Super Capacity Plus Top...
The "F24" error code is a heat sensor error code. The following link explains the error code in detail and the steps to correct it:
http://www.fixya.com/support/r1976126-f24_error_code_whirlpool_duet_kenmore
In many cases, the connector plug on the NTC sensor wiggles loose and causes the error code. Check the NTC connection first to make sure it is tight and making good contact. This may save you a service call and/or replacement parts. Make sure you UNPLUG the washer before servicing anything inside the unit.
A replacement NTC module (if required) can be purchased at searspartsdirect.com for about $10. Refer to the parts illustrations under the "Tub and Basket Parts" heading.
If you have any questions, please let me know. I hope this helps you.
NOTE: Each washer comes with a technical data sheet located inside the cabinet. You will need to remove the lower toe panel directly below the door to access it. If it is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all troubleshooting tips, wiring diagrams and fault codes with explanations.
Dec 09, 2009 | Kenmore HE2 Plus Front Load Washer
Flashing F24
All Kenmore appliances are built by other manufacturers, therefore you will need to provide your complete model number in order for us to determine who made your washer. Once we determine this, we can diagnose your error codes for you.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we will attempt to get your washer repaired for you.
We look forward to working with you. Thanks, Ella
Nov 13, 2009 | Kenmore HE2 Plus Front Load Washer
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
F24 error code
Take off the lower panel of your washer and under this panel on the back of panel is a book which tells you what the error codes are and how to fix them or test for them. It looks like a tempature sensor code to me.
Apr 19, 2008 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
341 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
