Question about Brother MFC-640CW All-In-One InkJet Printer
No Cartridge installed on Brother MFC-640CW
Have tried to reinstall ink cartridge several times, keep getting message: No cartridge installed, open scanner cover, then reinstall ink cartridge. Used new cartridge, different cartridge, took them all out, nothing seems to work. Will not go to cleaning cycle.
I need insteled solfwere of the mfc-640cw
Posted on Oct 29, 2009
Brother MFC-640CW All-In-One yellow not printing
if your print head is removable (the thing your ink cartridge clips into) remove it and clean it out with asorbic alcohol on both the print face and the ink inlet area- If your yellow has been empty for a while before you bought a new cartridge, it is possible that ink has dried in the ink channels of the print head and this is almost impossible to repair and you would be better off buying a new print head- Also if you have a fairly new printer you can contact the manufacturer about your issue and they may or may not send you one for free- My KodaK AIO had the same issue and Kodak replaced the print head for free all I had to do was take the time to call them
Apr 07, 2010 | Brother MFC-640CW All-In-One InkJet...
After installing new cyan cartridge, display reads No Cartridge
look at the ink cartridge and and first see if the ink covers the top of the cartridge. there is a little part of the ink cartridge the best way to explain it, is there is a tab,. that tab goes into a sensor. if the tab has ink on it, then you mostly like have a problem with the sensor itself. but if there is no ink, the printer is correct. i have had several people bring printers with those type of problems, and when they bring the cartridge i look at it, and they are practically empty.
thanks
Jun 26, 2009 | Brother MFC-5440CN All-In-One InkJet...
MFC-210C I changed the ink and keep getting a no cartridge message. I have reinstalled several times but I still get the same message.
Replace with old cartridge and if the problem still persists there has most likely been damage to the socket caused by replacing the cartridge. If the message does not exist with the old cartridge then there is something defective with the new cartridge.
Nov 17, 2008 | Brother Office Equipment & Supplies
No cartridge?
Unplug power cord ten minutes to reset the printer
Check that the cellotape strip on top of cartridge had been removed.
Pull out and put back the cartridges.
Clean the cartridge carriage metal plate that makes contact with the cartridge, use isopropyl alcohol and cotton to clean.
If it still does not work, the new cartridge may be faulty, get a new set of cartridges, possibly original ones.
If you still get the message, the contact in the printer carriage is fgaulty, the printer need repair.
Oct 11, 2008 | Brother MFC-640CW All-In-One InkJet...
Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Jun 27, 2008 | Brother Multi-Function Center MFC-3360c...
New ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Jan 28, 2008 | Brother Multi-Function Center MFC-240C...
Will not accept new yellow ink cartridge.
Do you use generic carts?
If yes try another cart (always best: original brother carts)
http://welcome.solutions.brother.com/bsc/public/us/ca/en/faq/faq_list.html?reg=us&c=ca&lang=en&prod=mfc210c_all&Cat=11
Dec 23, 2007 | Brother MFC 210C All-In-One InkJet Printer
MFC 640CW not refilling with new ink cart.
Unplug printer from power. Wait a minute. Take all carts out. Plug machine to power. mfc demands carts. Reinsert carts (have a look if they all filled with ink!!). If asked press 2 (No change) despite you use a new cart press 1 Yes cart changed.
Should work!
Nov 03, 2007 | Brother MFC-640CW All-In-One InkJet...
Ink
If you don't have the cartridges seated properly you will get this message. Pull them and try again. Myself, I tried to save some money, and bought Brothers refilled ink cartridges. They wouldn't work, so only use new Brothers ink cartridges. Unplug the printer from the wall for it to recycle, don't use the power button. Good Luck
Apr 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-640CW All-In-One InkJet Printer Logo
395 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
