Question about Cub Cadet Garden
Inherited a 1170 13cd608g101 with a briggs, cuts off after 20 min
Inherited a 1170 13cd608g101 with a briggs 17.5hp(it was my dads)in a very sad state.I got it running ($362.00 later) it cuts grass great...for 20 minutes! it cuts off & won't restart for about a half an hour, then restarts and again worksgreat for 20 min. before in cuts off the idle fluctuates, then dies. it will restart again, but only run for 5 seconds on choke full on.what is going on?????????? It had been sitting for 2 yrs, I knew it was a task, but worth it. What was done mechanically: Drained old gas & cleaned out tank, carb bowl & carb itself, new fuel line & filter, air filter, oil filter & switched over to briggs synthetic oil, new spark plug (#5066 platinum, same as came out) and even used that pb blast mower tune-up spray to help cyl. seal, new belts (all 4) new blades, replaced all the worn steering parts,pullies & bearings, welded up holes in deck, sanded, and painted it up like brand new, heck i even waxed it! I'm starting to think I wasted my time & money just to show my dad that "the old cub, could be just as good as the new one" I have noticed it runs longer before cutting off when not enguaging blades though. i thought maybe its not charging the battery enough? my multimeter sals when running: 12.87v? I don't know I'm lost ...and frustrated...and my grass is getting taller! Can you help me????
  • 389 Answers
From what you describe, it sounds like perhaps your magneto is breaking down when it gets hot. To test it, you will need an inline spark tester and as soon as it dies, try to restart it with the tester in place and see if you have spark. If not, replace your magneto.
When testing your battery with the multimeter are you running it at full RPMs? It should actually be putting out about 13.5 to 14 volts at full RPMs to keep the battery charged up good especially if it has an electric blade clutch.
FYI you can go to http://manuals.mtdproducts.com and with your full model and serial number you can download some excellent information including a complete service manual. They have 9 different manual you can download and should be of great help with your tractor
Posted on Oct 06, 2009
Where is mixture adjustment on B/S 20 hp v-twin carburetor?
sad to say Briggs made them non adjustable A long time back
May 23, 2015 | Garden
Briggs & stratton v-twin engine cuts out
acid dip rebuild carb make sure fuel selinoid on bottom of carb moves freely
Sep 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Brand new B&S 5000 watts generator,bought at H.D. Out of the box, set it up , checked oil level,OK!,filled with gas,OK!.started right up! ran for 5Mins to break in. Plugged in skill saw, made my cuts....
There really is not much you can do without voiding your warranty. This may be something simple like a connector that vibrated loose inside the control panel. (Alternator to contol panel inter-connect) There could also be a wire lying loose that was not connected. Open the control panel... and look for anything obviously out of place. DO NOT do anything else. After that your stuck with the warranty process of Briggs and Stratton.
http://www.briggsandstratton.com/~/media/PDF/BriggsStratton/Engine_Warranty.ashx
or 1-800-233-3723
When your at a B & S service / repair point... (store front)
Things to note .
1. Tell servicer unit is for PRIVATE USE (There is no warranty for commercial use)
2. Have proof of purchase in hand otherwise they will use the MFG date as the start point of the warranty. Many generators sit in a warehouse or on the shelf long past an implied warranty (date of mfg) Bottom line you need to have your sales slip.
There are several things I could have you do but... as the consumer the only thing you can do is perform an inspection. By opening the control panel you need to tell the servicer the only thing you did was a VISUAL Inspection...... Anything else will void your warranty.
So.. look for any obviously loose parts or or connectors. After that sadly your stuck with dealing with warranty service.
Thanks for choosing FixYa,
Kelly
Sep 04, 2011 | Briggs & Stratton Briggs and Stratton...
Need manual for Murray 20" cut 3.5 hp Classic push
This engine is one of Briggs & Stratton`s basic engines, quite a simple engine, post your problem and i`ll answer,
If you really feel that you need a manual they are available through some outlets, try Wal Mart. or ebay
Jul 03, 2011 | Briggs & Stratton Garden
Brigss and Stratton engine getting to much fuel
I HAVE A BRIGGS & STRATTON INTEK 18.0 ,JUST FINISHED CUTTING THE YARD,WENT BACK ABOUT 20 MINS LATER TO PUT LAWN TRACTOR AWAY. WILL NOT TURN OVER WHEN I TRY TO START, FUEL LEAKS OUT OF THE EXHAUST AND AROUND THE BOWL
Jun 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
2005 Poulan PD17542LT Lawn tractor, It starts fine but after cutting my front yard (20-30min) it dies, it will start up but dies in a few sec. If I let it set and cool off I can get 20=30 min till it gose...
Normal maintenance been applied to this rider ? Filters, lube, cleanings ? This sounds like an electrical issue (component hot), or a vacuum in the fuel tank. Next time it 'stops' open the fuel tank up and listen to any air 'whooshing' in.
Jun 22, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
260 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
