Question about Microsoft Xbox 360 Console
Failure connecting to XBox Live
When trying to connect to XBox Live a screen appears telling me the connection has failed, I test connection and everything is confirmed except the XBox live. What should I do
  • 3 more comments
  • Anonymous Dec 23, 2007
    Yes I have the same problem...Could it be that they are experiencing some difficulties? or maybe running some system updates
  • Pablonium65 Dec 26, 2007
    Everytime I try to play gears of war online, the system disconnects me from xbox live then tells me I need to connect to xbox live. when I initiate connection, it fails. when in the dashboard, I can connect with no problem. I can also play Holo3 online with no problem, so I know their system is up and running.
  • kevin28 May 12, 2008
    ip address failed
  • Anonymous Oct 01, 2008
    xbox live connection failure
  • giau1988 Oct 01, 2008
    yeah when i tried to connect to xbox live, it won't let me, i tried reconnecting and everthing connected, i tried the ethernet and wireless they work perfectly, but when it gets to xbox live it failed, i don't know what's going on it might be still updating but it's really sucks, please help
Posted on Oct 01, 2008
Same here
Posted on Dec 26, 2007
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href=""></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href=""></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
I can't connect to xbox live , it tells me to test my connection , its going fine , halfway to through the xbox live bar then an update pops up , if i say i dont want it , it signs me out of xbox live
have you tested the Internet connection? what are you using wireless or wired? this isue comes up sometimes when you use wireless and it looses signal... this can happen if the xbox is too far from the wireless router OR there is interfearence ebtween the 2 devices (microwave, wireless phones, etc.)
Apr 13, 2009 | Computers & Internet
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
It wont go on live it keeps sayin fail when i try to connect
What does it say? For example ( IP Address failed?, DNS failed? Xbox Live Failed )
test your xbox live connection to do this
Mar 27, 2009 | Microsoft Xbox 360 Console
XBOX live
1.make sure if you want to sighn into xbox live you make an xbox live connection test and a media test.
2.make sure if you have a gamertag, it says XBOX Live under your profile name and select recover gamertag.
3. if 1 and 2 do not work try changing console settings and/or change gamertag.
Mar 04, 2008 | Microsoft Xbox 360 Console
Can't get Xbox live to Connect to Xbox Live
wait 30 secs then turn it on then wait 30 sec to dotest
Mar 02, 2008 | Microsoft Xbox 360 Console
Xbox live test fails and so does update
you need to open the port that the update is trying to go through. the easiest way is to turn your firewall off, but this opens up your security. another way is to forward the correct port through port forwarding on your router. findout which port xbox live uses and put in the information to the router
Jan 06, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
call 1-800-4myxbox they are microsofts experts.
other things you can try are unplugging your modem and waiting 3 minutes wiat till all lights are on then try xbox live again it would help if you tested your connection and could tell what it failed on then i could pinpoint the issue and provide better help.
Dec 23, 2007 | Microsoft Xbox 360 Console
Connecting to xbox live failing
The xbox live board is down,so if you pass all tests except the xbox live one,this is the problem.I rang them and they said over 50% of users are having this problem.Its because so many people went on it over Christmas and the system got overloaded.They said they're working on it and it should be up and running in a week or two. ~~PS~~ I rang on the 12-1-08 so it should be up by the 20th,its not your fault,the servers down.
Dec 22, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
299 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
