Question about Midland Amateur&Consumer Radio Replacement Batteries: 70B-75.....1400 mAh 7.2V NiCD
Setting up a 70-382B and 70-530B Radio's as link radio's on an Amatuer Repeater
I do not have the service manuals for these radio's. I want to wire it up for use as link radio's on my repeater. I need to use the connector on the back of the radio. The one that the (+) and (-) wires are coming thru.
Any help would be appreciated and If anyone has available a service manual I would like to get a copy.
    New Friend:
  • 109 Answers
Pin 1 auxillary 1
Pin 2 mic hand up ground
Pin 3 Mic hang up center conductor
Pin 4 and 6 for external speaker
Pin 5 and 6 jumpered together for internal speaker
Pin 7 Ground
Pin 8 not shown
Pin 9 13.8v DC
I have the manual for the 70-382B/482B but for shop use only
I'll help you with any information I can.
Posted on Aug 22, 2008
How to change bands. The radio won't go below 220.00MHz. I want to go to Hit my repeater at 147.120MHz ? HELP
your repeater transmits at 147.120,your radio transmits on a different frequency to the reapeater otherwise you would repeat right from the radio,you need to program your radio and repeater together,try a baofung radio and vertex 100 repeater,i have them and they work good,the radio is 30 bucks on ebay
Jul 13, 2015 | Universal Professional TYT TH-9000 VHF...
My motorola radius GP 300 suddenly stoped working, disconnected from programmed network, how can i connect back and sees it working back?
GP300 radios will operate either radio-to-radio or in conjunction with a repeater. If your radio no longer works through a repeater, you might check to see if it will work in talk-around mode (radio-to-radio). Check with your repeater service provider to see if the repeater is in working order. One other item which might occur with a repeater would be if your radio is no longer recognized by serial number by the repeater. This is also something the service provider could help you with.
Best regards.
Apr 21, 2013 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
How do I program a yaesu ft-270?
I will be working from the online version of the manual located here. It may or may not be the same as your printed manual included with the radio - so you might want to download this copy.
First, let's set the radio to automatically set up repeater input shift based on the published receive frequency. By default, the 270R will transmit 600Hz up or down as determined by the band plan. This feature is called ARS and can be disabled if desired. If it does not display a frequency 600Hz up or down from the receive frequency while transmitting, is has been disabled. Let's re-enable it by performing steps #1 thru #5 on page 19 of the manual. Once completed, the 270R will automatically shift the transmit frequency (to match the repeater input frequency) as shown in the top half of the "ARS-Repeater Subbands" graphic at the bottom of page 19. The bottom half shows the export version of the shifts and does not apply to USA versions. If you have "odd splits" (repeaters that have input frequencies that are non-standard ie: other than 600Hz; or shift up instead of down and vise-versa) you'll need to manually change these later as described in VHO Split Mode on page 21. Any repeater operating on 147.000Mhz may have a shift either UP or DOWN. As you can see in the graphic, 147.000 is between the (-) and (+) shift so it could be either direction. Double check to make sure the radio matches the shift that the particular 147.000Mhz repeater you wish to access requires.
Next, create a list of repeaters that you wish to save in memory (you can check online databases to obtain the most recent information). This list should include Name, Receive Frequency, any non-standard direction or value Shift (called "odd splits), Tone Type and Tone. The name should be 6 or less alpha-numerics in length and be something that helps you identify it . This could be the name of the repeater owner: "TIM, PETE, etc. ", the name of the club that runs it: "BARC, CMARA, etc.", the city or town it is in: "BOSTON, OAKLND, etc,". You might run into names that would create duplicates when there are more than 1 repeaters there in the same location. Boston has several 2M repeaters - naming them BOSTN1, BOSTN2, etc. may help you remember them, but it will be easier still to append the decimal portion of the frequency to remember - such as in the case of a Boston repeater on say, 146.030Mhz and one on 145.150. BOS030 and BOS150 would probably be easier than trying to remember which is BOSTN1 and which is BOSTN2. Placing the names in the 270R memory is the last thing done, so don't worry too much about a name for the 270R's display just yet.
Most repeaters use CTCSS for access. Some newer repeaters use DCS. Some require or even prefer that no tone be sent at all. CTCSS is an analog frequency and a DCS code is digital data. The repeater may require one or the other to be present to "wake up" and begin retransmitting your message. All you really need to know about these two systems is the you need to match both the tone type and the tone value to successfully activate the repeater. Set the radio to your desired default power output level. Tap the VFO button once to enter VFO mode (if not already in VFO mode).
Enter the repeater's receive frequency by twisting of the tuning dial (page 13) or by direct entry (page 14) via the keypad. When using the keypad, do not enter the leading "1" of the frequency - as all the frequencies that this radio can tune begin with "1" and can not be changed. With the repeater frequency displayed, next enter the CTCSS tone for the repeater as described on page 23. If the repeater uses DCS, follow the directions that begin 1/3 of the way down on page 24 instead. As far as "TONE" and "TONE SQ" are concerned, the difference can best be described in that a radio working on a repeater system benefits from use of TONE, and a radio working on in simplex operation (no repeaters) benefits from the use of TONE SQ. Since we're programming repeater frequencies, there's no need to select TONE SQ. If the repeater strips the tone from its output, your radio will remain silent if set for TONE SQ. TONE is a much better match for our needs. Remember, you must use the DIAL to select the CTCSS tone frequency or DCS Code. Unlike the repeater receive frequency, it is not possible to directly enter the tone frequency or code via the keypad.
At this point, the radio should be displaying the recieve repeater frequency. Since automatic repeater offset is enabled - the 600Hz offset frequency and direction are set. The tone type and value for this repeater frequency have just been set in the previous paragraphs as well. Now it is time to write all this information to the radio's memory. This is detailed 1/3 of the way down on page 29 under "Memory Storage". Once you have performed step 5 in Memory Storage for this first repeater, it says to repeat this same process. This means setting the next repeater's recieve frequency, tone type and tone value - just as you have done with the first.
Once you have made sure that you have unique names assigned and the other information above, you are ready to begin adding them into the 270R's memory. You can go back add names to be displayed instead of the frequency of the repeaters if desired. Page 31 details the procedure to assign an alpha numeric name to each memory location. Make sure that you are assigning the correct alpha-numeric to the repeater by checking the frequency from time to time - don't blindly add alpha-numerics to memory channels.
This is a very tedious process. Ham Radio Outlet offers Windows programming software and transfer cable by Yaesu called "ADMS-270" for $38.95. This package allows you to easily create many lists of memories on your Windows PC & keyboard that can be uploaded and downloaded "on the fly" I highly recommend this software - or any software that allows you to program the radio from a computer rather than the radio itself.
I hope this was helpful.
Nov 29, 2012 | Yaesu Ft-270r Vhf Ft 270r Ft 270 R
Radio Shack 61-2470 manual
I haven't found a complete manual as such, but you can download each section (then print from browser) from the radio shack web site. I have provided the link below:
Apr 17, 2010 | X-10 X10 Smart Repeater Remote Controls
I have a midland twoway radio I dont know if its a VHF or UHF model # is 70-530B also need mic wiring thank you...
It is a 25W UHF radio 445MHz-455MHz
Type accepted for land/mobile.
Sorry, no info on the mic wiring.
Oct 04, 2009 | Midland Radio Communications
Repeater channels
Are you certain you are near a GMRS repeater in your area? If you have your radios set for the GMRS repeater channels the radios will not talk to one another unless you are in close proximity of a GMRS repeater. To talk radio-to-radio you would need to set your radio to one of the simplex frequencies available in the radio.
If you know you are close to a GMRS repeater, you might double check the Tx and Rx frequencies of the repeater to be certain they match the settings in your radio. Also, you will need to be certain your interference code is set to zero (the off position) to be used with the repeater. I didn't read up on the T7200, but if it has a Qt filter, set it to zero also.
Jul 26, 2009 | Motorola Talkabout T7200 (22 Channels)...
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
Amatuer radio
Click on this link to dlownload your manual in PDF format.
If you found my solution useful, please rate me as "Fixya".
Please let me know of I can be of further assistance to you!
Good luck & 73,
- Jim
Mar 19, 2008 | Radio Communications
Alinco dj-v5 HT deviation adjust
To adjust the deviation of this radio, you don't have to take it apart. If you take the battery pack off, there is a sticker on the back of the radio saying Alinco. Pull that sticker off and underneath are the variable resistors. See the service manual for more details on how to make other adjustments.
First, make sure you note the present position of this pot so you can turn it back if you have to.
If you don't have any equipment to measure deviation, make a contact on the repeater and try turning the pot in small increments and ask the person to help you set the deviation so your voice sounds good through the repeater.
Once set, if the repeater has a touch tone test, go through and make sure all your tones are being properly decoded.
Please let me know if I can be of further assistance to you.
- Jim
South Hills ARC
Feb 26, 2008 | Radio Communications
Radio Communications Logo
712 people viewed this question
Top Midland Radio Communications Experts
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
