Question about Radio Shack Pro-95 Handheld Scanner
Im getting nothing
I used to get all local chanels i replaced the batteries then i used the reset button still nothing any help please
  • 3,153 Answers
You have done the most obvious steps but you may also want to check that the squelch is not turned up to high if using it in FM freq. On some scanners the squelch may have a different function when used on AM USB etc.
Check that any noise blanking functions are not set incorrectly too.
A quick check would be ti tune to a known FM radio station in your area that you can hear on a normal radio and then do the same with your scanner. If using FM also make sure you are using the correct FM eg FMW or FMN wide / narrow.
I have included the links and info below and will let you take it from there
Heads up that in some countries / States scanning can carry severe penalty.
I cannot give any direct information and it up to you to make sure you apply to the laws of your state etc
A good source of information are the two sites below
Frequencies
Scanner software
With any luck you will also find either the manual or a link to it there as well as quite a lot of other useful information that would give you guidance as to the legality and use of your scanner.
Posted on Oct 05, 2009
  • 3,051 Answers
Helo there:
if the radio is working just go to yahoo and search for this : police scanner frequencies then just look for your area and enter the numbers and you will be able to hear local stations ok?
best regards michael
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
Fresh out of the box and will not turn on
Why wait? Take it back for replacement.
Dec 28, 2013 | Vtech Kidizoom Digital Camera
Having trouble starting it up. I push the power button and nothing happens at all. I even tried draining the power by removing all power sources and holding the power button, but it still didn't work,...
ok check your charger to see if the light is on if not that is the problem try changing the fuse in the plug.
or replace the charger.
take out the battery plug in the charger try to boot up if it works its the battery.
falling that you may have a loose connection on you DC jack replace it this is a problem im coming across more and more DC jack replacement is not that cheap find a local engineer he/she will do it for a fraction of the price compared to pc world.
Oct 06, 2010 | ASUS Eee PC 900 Notebook
When I hit the on button for a dialtone it just keeps blinking and then shuts off. Sometimes if I keep at it, it will stay on but the Static or shwisshing sound is like something out of a Stephen King...
ok it sounds like there may be a battery problem.
if there are chanel buttons try changing chanels.
if not you may need to replay the battery.
Nov 13, 2009 | Uniden Cordless Phone
How record tv chanels using the DTV converter box? The converter box determines the chanel of interes while the DVD recorder must remain on chanel 3 in my area. My DVD recorder is a combo with a VCR...
Can you connect directly from the DTV converter to the DVD recorder input using RCA phono connector cables? You'll have to select the input on the recorder menu as well.
Oct 21, 2009 | GoVideo Go Video DVD/VCR Combo
Hi im using the iphone 2g, first of all, my sleep / wake button didnt work a few months ago. So i cant turn the iphone off or use any restart mode without using jailbreak software, just now, the iphone...
To reset your phone you need to hold the power button and home button. Because you cannot do this, I would open up the iphone and repair the button. To open up easily use a -> iPhone Cheetah Mount and replace or fix the button. The iPhone is like a computer, it needs to reset at times. Your only solution would be to let the battery drain to zero and plug it back in.
Jul 01, 2009 | Apple iPhone Smartphone
Getting regular cb chanels
go to cbtrick.com to radio information go to corba radios and you will find the mod for 11 meters.
Jan 01, 2009 | Cobra 150 GTL DX Base CB Radio
ORION TV 1926A
lost the remote?... try a different universal remote. i have a orion 27" but i think it has a menu button on the front of the set. im at work.. when i get home ill check and repost....if you dont want to buy another universal.. barrow a friends and give it a try... sometimes the manufacture puts updated CODE's for the remote on the website.. might check that as well. good luck.. more to come.
Jan 22, 2008 | Orion1934 19" TV
When i hook up dvd/ps2 i cant get it to show up on the screen
You have to have a remote control to set the chanel to 00. You cannot set the chanel to 00 with the chanel buttons on the front of the tv.
Jan 02, 2008 | RCA F20352SF TV
Radio Shack Pro-95 Handheld Scanner Logo
139 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
