Check if you get water from the tap without water timer.
Look for obstruction in filter washer (rubber washer with screen mesh to keep debris out of timer)
Battery operated water timers are made to last few years, and cannot be exposed to freezing temperatures or hot sunlight http://waterheatertimer.org/Gardena-timers-and-manuals.html
Hi First try to Restore it by selecting Restore Only from the phone setting.After successful restore setting is done please check the time setting.Good luck
morning
your phone freezes becouse it has software or hardware problem or the Eprom chip has gone bad try re installation of phone operating system if there is no change the chip is bad I suggets u buy another phone
Hi, The reason the clock won't keep time and date is because the CMOS battery is dead, this battery inside the laptop keeps the date and time in the BIOS even when the laptop has no power to it. I recommend you take the laptop back to where you bought it from or call the manufacturer as you are still covered by the warranty. They will either arrange for the laptop to be sent in or send you to a service center. It's also a good idea to mention that the touchpad freezes too.
The 163 error is a BIOS Date & Time error. Go tinto the BIOS setting and set the Date & Time. If you boot up the next time and you get the same error, this is cause by a flat BIOS battery, replace with a new battery.
The 8611 error relates to the PS2 mouse bus connector, try a new mouse or use a USB mouse.
Sounds like the camera OS is running into a problem when it tries to store the new date information to memory. The data path could be corrupted, or it could be a faulty internal battery. Hopefully your camera still works when you bypass setting the time and date, so you can still use it.
yeah i know what you're saying! my phone works fine, but it's just sending the texts is what freezes mine, and i dont want to lose my info. either. i wonder if there is a solution to fix this? my dad found that there is some setting configuration that will set the texting settings to normal or something, but he's working on that now, but i will keep posting updated information!
go to motorola.com/iden click united states click support click software downloads (if you have pictures and videos download iden media downloader to retain them) click software upgrade click your phone model make sure you select a date within a year for the warranty info you will need a data cable to make this work try to redownload the software to your phone this might help
