Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
SPARK PLUG BROKE DONT KNOW MAKE AND MODEL OF MINI BIKE.SPARK PLUG SAYS LT7 LD
  • 8,404 Answers
Halhbec is correct, you have the important part and you indicate you have the plug number. Im not sure you can get the help you need at a "fast food" style auto parts place, but the NAPA susggestion is a good one ...
In my experience, the counter person at the other places don't have the experience or the knowledge or the inclination to examine a little problem. But you could get help there.
Thanks for posting on FixYa.com
Posted on Nov 02, 2009
  • 770 Answers
Not that critical. If it broke, I'm betting it was the insulator, (the white porcelin part), if I am correct, continue removing the plug, and take to a parts store...NAPA, Auto Zone, Advance, etc, the critical part is not the part that broke, but rather the length and diameter of the threads.
Posted on Oct 05, 2009
My dr 1990 model wont fire
try pulling the plug, stick a screwdriver in the end of the spark plug wire and hold it to the metal of the bike try starting it if it has fire you wil get a spark. if no spark try checking the points they may have burned out
... good luck
Jun 02, 2012 | Suzuki DR 750 S Motorcycles
NO SPARK AT SPARL PLUG
What is the year make and model? When you tested the spark plug did you put the metal screw side of the plug up against an unpainted section of the bike such as the engine while the other part was still connected? If you didnt do that you wont get a spark even if the spark plug is good. Did you try to swap out spark plug to see if it was the spark plug just going bad? With out what kind of bike it is I dont know if it uses a magneto or not.
Mar 30, 2012 | Motorcycles
Why does it cut the power while I am riding the bike
I have just had a similar problem but my bikes a 2006 model,approaching trafic lights it would just cut out and sometimes trying to riding on a straight road.The AA will say its the battery,dont believe him Its the spark plug,get a hot spark plug,my bike performs better now.
Nov 27, 2010 | 2005 Honda CBR 125 R
Suzuki TS125R (1994 model), not TS185: Trouble starting
I have same problem with my ts 125r i solve problem with new spark but not NGK BP9ES i put another spark plug am not sure about her name i thik its Golden Wathes with four pips.U must measure leght and widht for this spark plug and heat power. Peace
Apr 09, 2010 | 1981 Suzuki TS 185
I have a yamaha virago xv250 03' model. Its done
first thing to do is to drain oil from your motorcycle use wrench 17(size may vary) to open the bolt under your bike and place a drain bucket under it, then remove spark plug using spark plug remover, as for the filter you can use a cross screw driver to remove the air filter, once you replace the spark plug and the air filter let the oil subside for about 3hrs, then return the bolt and place new oil, i dont know if this help but i hope it will
Sep 18, 2009 | 2004 Yamaha Xv 250 Virago S
Pocket bike prblems
Get some engine starting fluid and spray a small amount in the air intake. If that doesn't work take out the spark plug and see if it sparks when you pull the cord and make sure it is not fouled. If it is wet with fuel dry out the plug and pull the cord a few times to clear the cylinder. Fresh premium fuel always works best on temperamental engines.
Sep 06, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Cylinder one and two have trouble firing, and besides the petcock on the gas tank, there is another fixture on it as well, with and export hose mount, and i dont have my choke hose in on the carbs, my...
check the condition of the spark plug if it is black you must check the spark with a new plug, make sure there is no gas fumes present when doing the spark test. attach plug for cylider in quest to the wire use a jumper wire with aligator clips on each end to hook onto hooked tip of plug the hook the end of jumper to ground pull out the other plug wires so the bike won't start during check turn over the bike look for a blue or purple spark if you don't see this color (spark is white or yellow) the coil or wire from coil is bad, replace. If the spark is good the carb is flooding the cylinder and must be removed and cleaned.
Jul 08, 2009 | 1980 Suzuki Gs 550 L
My 50cc mini bike starts then dies 5 secs after starting. why?
It sounds like you may have 2 problems
  • Bad gas
  • dpossible loose spark plug( bad compression)
Solution
dump out the gas put new in
Remove the spar plug and examine the plug if it is wet and black it is fouled
if it is white ad dry it is not getting gas
If you can replace the spark plug if not just clean it with a wire brush put back in and tighten
Finally make sure the spark plug wire is not lose
Best of luck to you
Jan 01, 2009 | Mini Motorized Bike
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
188 people viewed this question
Top Quad Cycling Experts
shaun taylor
Eric Hidle
Level 1 Expert
Are you a Quad Cycling Expert? Answer questions, earn points and help others
