Question about Frigidaire Washing Machines
Frigidaire does not recognise the model number #FTB4000FS1
Frigidaire does not recognise the model number of my frigidaire front load washer. Model # FTB4000FS1.
  • steve
    steve May 11, 2010
    Neither do any of the 5 major appliance parts supply companies I queried. Double check your number and re-post.
I believe the correct model number is FTFB4000FS1...you may have forgotten the second "F".
Posted on Oct 20, 2010
  • rykdawgg Oct 20, 2010
    I believe the correct model number is FTFB4000FS1...you may have forgotten to input the second "F".
Can you tell me what size capacity this front load washer is?
Good Morning Friend, that's a great question!
In order to provide you the correct size capacity of your Frigidaire front load washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front, as you open the door. Thank you and I look forward to further assisting you! - Z
Sep 05, 2014 | Frigidaire GLTF1670A Front Load Washer
How to clean frigidaire front loading washer
In order to provide you the correct instructions on how to clean your Frigidaire washer, I would need your model number please? You can normally locate the serial tag (which lists your model number) on the upper front, as you open the door. Thank you and I look forward to further assisting you. - Z
Sep 04, 2014 | Frigidaire Washing Machines
What is the drum size of the washer?
Hello Friend, that's a great question!
In order to provide you the correct drum size of your Frigidaire washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front as you open the door if you have a front load washer. If you own a top load washer, you may find the serial tag inside the lid, on the right side. Thank you and I look forward to your response.
Jul 24, 2014 | Frigidaire FWSB5700DS Top Load Washer
Where is the switch located on the front door of front loader washing machine
In order to provide you the correct location of the door switch on your Frigidaire front load washer, I will need your model number. The serial tag, which lists your model number, is typically located on the upper front, as you open the door. Thank you! - Z
Jun 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
Where is model number located
Good Morning Friend, thank you for your question!
I see that you are inquiring the location of the model number on your Frigidaire washer. The serial tag, which lists your model number, is typically located on the upper front, as you open the door on a front load washer. If you have a top load washer, you can find the serial tag inside the lid, on the right side. I hope this information helps to some degree. If I can be of further assistance, please feel free to reconnect.
Best regards! - Z
May 19, 2014 | Frigidaire Washing Machines
I need a manual for the Frigidaire FAFS4272LW Front Loading Steam Washer
Hello Ann Todd - I located the manual on the Frigidaire website. Here is the manufacturer link and according to your model it seems like the direction of the door swing cannot be change. If you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data.
Feb 16, 2013 | Frigidaire ATF6000ES Front Load Washer
Where do you find the model # for a frigidaire washer? The tag under the lid has been removed.
Hello saguilar891 - Generally speaking, the model and serial numbers on Frigidaire front load washers are located on the upper front, as you open the door.
Nov 12, 2012 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Frigidare front load washer warranty
The usual factory warrenty periord on the Frigidare Affinity washer is 1 Year from date of purchase. You can find your Model number and serial number of your washer on the inside of the door. It is on a white label towards the bottom of the dorr.
Nov 10, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
266 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
