Question about Hotpoint Ovens
When oven is on turns its self off after so long then dosent come back on for sevral minutes sometimes 15
    Guru:
  • 310 Answers
We see a common problem caused by a control board failure where the oven shuts off after about 30 seconds, as if you had pressed CANCEL. We repair oven control boards at www.fixyourboard.com.
Posted on Oct 05, 2009
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Oven door will not open after self clean
There are two easy things to try to fix this.
First, unplug the oven, or turn off the circuit breaker to it - so long as power is cut to the oven. Leave it for about 5 minutes, then plug it back in or turn the circuit breaker back on and try to open the door.
If that doesn't work, turn on the self-cleaning cycle again, and let it run for about 15 minutes. Then turn it off and wait another 15 minutes, and see if the door will open.
If neither of those work, you have a more serious problem with the locking mechanism. Either a bad solenoid or a damaged heat locking mechanism. Both of these will require removing the stove top to access and repair. Let me know if the above suggestions fix the problem. If they don't, I will get you more specifics on repairing the locking mechanism - assuming you're up for that.
-Dyllan
Mar 06, 2008 | Ovens
I used the self-clean for the first time and my oven door is still locked and the display doesn't work at all. Model #YKESS908. What can I do to unlock the oven door? I have checked the circuit...
Hi
You can set the unit on self cleaning and then after 15 minutes stop the cycle, let it cool down for an hour and then open the door. If the issue remains then you'll have to replace the door lock assembly, then you can open the door with a coat hanger by pulling the latch towards you. Hope this helps...please post back for further assistance.
Daniel
Sep 09, 2011 | KitchenAid Ovens
We are renting our townhouse. It came with a gas Kenmore oven. Someone (maybe even me) has done something to trigger the "LOC" display on the oven, meaning the door is locked, presumably for...
Hi
First press the CANCEL/Delay button for 20 seconds...If this won't work then you can start the self cleaning cycle again and then stop it after 15 minutes, then let the oven cool for sometime and check if the door opens again, if the not then you have to take a screw driver and open the latch. After this the latch mechanism should be replaced as it is bad. Hope this helps...please post back for further assistance.
Daniel
Jan 26, 2011 | Kenmore Ovens
Oven door is locked shut. Latch for self cleaning won't fully open. Thanks
FIRST TRY TO TURN THE BREAKER OFF FOR ABOUT 20 MINUTES, IF THAT DOESNT WORK YOU WILL NEED TO PULL IT OUT AND REMOVE THE BACK PANEL ( UNPLUG IT BEFORE YOU WORK ON IT) THEN LOCATE THE DOOR LOCK MOTOR AND ROD, SOMETIMES THE ROD NEEDS ADJUSTING, SOMETIME THE MICRO SWITCH ON THE MOTOR GOES OUT,, YOU CAN GET IT ULOCKED AND STILL USE IT, BUT YOU WONT BE ABLE TO USE THE SELF CLEANE,, YOU WILL HAVE TO FIND OUT IF IT IS THE MICRO SWITCH OR THE MOTOR AND RELACE THE PART BEFORE YOU CAN USE THE SELF CLEAN
Jan 19, 2011 | Maytag CWE4800A Electric Single Oven
I started the self-cleaning process on my GE electric oven last night. The process is complete but the oven door will not unlock. It sounds like it keeps running and running.
Hi
You can start the self cleaning cycle again and then stop it after 15 minutes, then let the oven cool for sometime and check if the door opens again, if it wont work then press the CANCEL button for 20 seconds. If the issue returns then you have to take a screw driver and open the latch. After this the latch mechanism should be replaced as it is bad. Hope this helps...please post back for further assistance.
Daniel
Jan 17, 2011 | GE JTP15 Electric Single Oven
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
I ran the self-cleaning and the door will not open.
or
Mar 06, 2010 | Whirlpool Ovens
Oven door will not unlock
Hello,, Some times this will happen after a self clean cycle if the timer did not finish the entire clean. Try to set the clock to start the self clean again then simply end the self clean. This should unlock the door. If the door remains locked. You may check the oven for an error code, or the door latch itself may need to be replaced. One other possible would be to turn off the power to the oven and try to let the oven control reset. leave the power off for about 15 minutes then turn the power back on. That will sometime work aswell. Good luck and feel free to call me if you need more help.
MIchael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Ran self clean on my oven and it stopped in middle of cleaning cycle
That most likely means there is a fault in the control board. You need to contact the manufacturer or retailer for service.
May 17, 2017 | Whirlpool GBS277PDS Electric Single Oven
Ovens Logo
120 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
