Question about Frigidaire FRS3R4EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ 4 Button Ice/Water Dispenser & Cle...
ICE BUILDS UP ON BACK OF FREEZER AND FREEZER AND FRIDGE STOP COOLING. I PULL OUT THE PLUG FOR 3 OR 4 HOURS AND IT WORKS FINE FOR A FEW DAYS AND THEN GOES BACK TO THE SAME SITUATION. SETTINGS ARE AT FACTORY.
  • 308 Answers
Sounds like you are having a defrost problem. Most of the time it turns out to be the defrost timer. Hope this helps
Posted on Oct 05, 2009
Door wasnt closed properly over the weekend fridge starting to cool, no ice, freezer works display reads Er-1F
The door being open probably caused ice to build up on the evaporator, not allowing air to flow properly between freezer compartment and refrigerator, unplug the unit for a few hours and place a fan aimed at the freezer compartment to help it defrost then plug unit back in should be fine.
Sep 28, 2015 | Kenmore Refrigerators
My amana abl1922fes has quit cooling several times in the 5 years i've had it. We unplug it, let it set overnight and plug it back in and it cools fine for a few months when it quits cooling again. Can...
when it stops cooling, you will see some ice build up in the freezer. Letting it sit unplugged melts the ice and you will see some water under the fridge. Connect power and it works. Cause: don't overload the fridge and the freezer. Make sure the doors close snugly. Clean all lint build ups by vacuuming under and behind the fridge after switching off power.
Mar 06, 2014 | Amana Refrigerators
Freezer keeps building up ice on the condenser i think, and after a few day sitting the bottom part of the freezer freezes and the rest dont
I'm not sure what system you have but typically there is a defrost timer on the back of the fridge. Often you can barely detect where it is, as only the stem sticks out.
What worries me is the amount of moisture in your fridge. You did not indicate how long to make the build up, check your seals carefully with a dollar bill.
Sep 02, 2013 | Refrigerators
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
The fridge will operate fine for about 2 or 3 days and then the inside will get warm and melt all the ice. I will unplug the unit for a few days plug it back in and it will operate fine for a few days and...
Sounds to me like you have a bad defrost timer. As the freezer is working correctly, it is building ice on the evaporator. It sounds like it does not go into defrost, thus freezing up the evap coil, and stopping the evap from cooling the surrounding air. Hope this helps
Jul 23, 2010 | Frigidaire Refrigerators
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge not cold
HI thanks for your question. check to see if the fan motor is running in the freezer. that could be the problem. thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | Frigidaire FRT18B4A Top Freezer...
Frigidaire FRS3R4EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ 4 Button Ice/Water Dispenser & Cle... Logo
76 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
