Question about HP LaserJet 4100 Printer
HP Laserjet 4100 jams after about 50 print jobs
    Scholar:
  • 82 Answers
Most typical jams are caused by bad pickup roller or separation pad. When you pull out the paper tray, and look inside the printer above the tray area, there's a roller that is held on with a little clip in the center of the roller. Pinch that clip to take the roller out and clean with soap and water. do not use alcohol based cleaners, they dry the rubber up and shorten the life span drastically. The separation pad should be right at the front of the paper tray, clean that also. If your printer keeps jamming after that, you may have some more serious like a fuser going bad.
Posted on Oct 05, 2009
HP LaserJet 4100 for all applications in windows 7. When I go to print a document and click on print. The print screen exits, the print job doesn't processes, and the print queue stays empty. Noth
Ideas? Yes. I had this happen on an LJ 1000 while trying to print my tax return. I tried emptying the queue, removing power from the printer, etc, etc. What finally worked was to empty the queue (again), disconnect power from the printer, shut down the computer, plug in the printer again, restart the computer, queue up a print job again, and hit PRINT.
Hope this works for you
Apr 11, 2013 | HP LaserJet 4100 Printer
Hp laserjet 4100 show message "Toner out". I can't print anything. Help me!!!
TONER OUT
The toner cartridge has run out of toner.
Depending on how the printer has been configured, it will either continue to print or stop.
Due to the resolution of the toner level sensor, it is possible that a small amount of toner (less than one percent) might still be present in the cartridge.
1. If the printer has stopped, you can resume printing by pressing GO for each job.
2. Replace the toner cartridge.
Jul 14, 2011 | HP LaserJet 4100 Printer
Printer will not read toner.
Did it ever work? If it was printing before, what happened right before the toner error appeared. Did you replace the toner(this is an HP toner cartridge, right?), did you have a paper jam....?
Sep 24, 2010 | HP LaserJet 4100 Printer
Refurb HP Laserjet 4100. When we use OEM cartridges we get a repeating image, but this does NOT happen with a refilled cartridge. Suggestions?
turn on/off, unplug, wait a minute, plug back in, should reset.
take all paper out. check to see if any paper is jammed in the rollers
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order.
lastly, check make of printer trouble shooting web site for more information. hp has an awesome site for trouble shooting printing issues
hope this helps, good luck.
Apr 29, 2010 | HP LaserJet 4100 Printer
Hp LaserJet 4100 printer says its out of paper which is not the case, could someone assist me and figure what may be causes this problem? Thanks in Advance
Paper jams can occur in the following areas
1 Top cover and toner cartridge area
2 Optional envelope feeder
3 Input tray areas
4 Optional duplexer
5 Output areas (top and rear)
6 Fuser area
Solving repeated paper jams
* Check all the paper jam locations. A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
* If using a duplexer, check all areas (including under the duplexer).
* Check that paper is correctly loaded in the trays, that all three adjustments have been made, and that the trays are not overfilled. Make sure paper is under the front and back tabs.
* Check that all trays and paper handling accessories are completely inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
* Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
* Try printing to a different output bin.
* The sheets might be sticking together. Try bending the stack to separate each sheet. Do not fan the stack.
* If you are printing from tray 1, try reducing the size of the stack.
* If printing from the envelope feeder, make sure it is loaded correctly, pushing the bottom envelopes in slightly farther than the top envelopes.
* If you are printing small sizes, feed paper short edge first.
* Turn over the stack of paper in the tray. Also try rotating the paper 180°.
* Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the online user guide for paper specifications). Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or
irregular paper.
* Avoid using paper that has already been used in a printer or copier.
* Do not print on both sides of envelopes or transparencies.
* Print only on full sheets of labels and do not print on both sides of label sheets.
* Check that the power supplied to the printer is steady and meets printer specifications (see the online user guide for printer specifications).
* Clean the printer (see the online user guide procedures).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 09, 2009 | HP LaserJet 4100 Printer
Laserjet 4100 cancels printing jobs
If you can do the following and email me the output I should be able to help you.
Print the event log
The printer’s internal event log stores the last 20 errors and can be printed at any time. To print the
event log:
1 Press MENU until INFORMATION MENU appears.
2 Press ITEM until PRINT EVENT LOG appears.
3 Press SELECT to print the event log.
kw7157@yahoo.co.uk
Mar 20, 2009 | HP LaserJet 4100 Printer
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
Printing gibberish
gibberish printing is normally a sign of outdated print drivers. Try going to HP's support site and download the latest PCL driver.
Sep 22, 2008 | HP LaserJet 4100 Printer
Dark Background on HP Laserjet 4100
Several Options:
- Increase the Toner Density Level to 5
- Use freshly opened media
- Use a new print cartridge, if near end of life
- Run a cleaning page to clean the fuser
Jun 18, 2008 | HP LaserJet 4100 Printer
HP LaserJet 4100 Printer Logo
223 people viewed this question
Seeker5211
Seeker5211
