Question about Jl Audio 1000/1 Car Audio Amplifier
How to connect it
I wanta know which way is the best way to connect my 2 twelve inch w6''s to my JL audio amp 1000/1
    Sergeant:
    Champion:
  • 231 Answers
Bridge the amp and wire the JLs in parallel..then put some earplugs on ..lol
Posted on Dec 24, 2007
Box size for jl audio 12"w6 going in large trunk
call jl they will give you BEST box recommendation
If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
Jan 24, 2013 | Car Audio & Video
JL W6 ohm wiring issue
Parallel , all positives together , all negatives together . With 4 ,4ohm voice coils in parallel you get around 1 ohm .
Apr 23, 2012 | Jl Audio Car Audio & Video
I have 2 12 inch jlw6's and need a amp but dont know what would be better, if i get 2 jl 500/1 or 1 jl 1000/1, or if other amps out there would be good for a reasonal price, any advice would help...
yea the jl either setup will be good for those woofers but for the money an to get the power i would try a hifonics 2000 or the 2600 brutis or mtx or2 poweraqustic 4000 planet audio they will work great or give me a call there are a lot of amps to choose for the money an the power
Jul 08, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Try to install 3 12w3d6 subwoofers connecting 3 sub together to put them in box
You need to wire them according to the limitations of your amp you can pull a 1 ohm overall load just by connecting all of your coils in parallel- or you can get an overall load of 4 ohms by wiring each sub individually in a series configuration which will yield a 12 ohm load per sub -and then wire the 3 sets in parallel which will bring your ohms back down to 4. You can do a lot with that many coils it depends on your amp really-ideally a 1 ohm stable class d mono amp that is 1000-1500 watts rms would knock the **** outta those things JL is the good stuff.
Jan 16, 2010 | Jl Audio 12W3 Car Subwoofer
I have a jl 1000/1 amp hooke up to 2 12 w6 subs and when i turn the volume up half way the speakers cut out and amp stops working but i turn the volume back down and it works fine. what could this be?...
what is happening is the amp is going into protect mode because it most likely is at the wrong oms and is getting over loaded and shutting itself down to protect it self!
do you know what ohm load you are presenting to the amp? or what ohm are the subs ?
if you correct the ohm load it will fix your issue and make the system sound way better! let me know if you have any more question and let me know about the ohms! good luck
Oct 02, 2009 | Jl Audio 1000/1 Car Audio Amplifier
I need to find a good sub box for my 10 inch JL w6
Hello ama1228a,
You did not say what type of vehicle the box is to be mounted into. Many times, where the box goes dictates the shape and size you have to work with.
That JL W6 will work OK in a sealed box with as little as .625 CuFt of volume and a ported box with .75 CuFt, so you have lots of choices.
Here's a link to the PartsExpress box page. These are Goldwood boxes, so don't let the prices scare you away. They really are built well, and one of them will make your JL sound good.
http://www.parts-express.com/wizards/searchResults.cfm?FTR=&search_type=main&WebPage_ID=3&searchFilter=goldwood+boxes
Hope this helps.
Apr 02, 2009 | Jl Audio 10W6v2 Car Subwoofer
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
What eq settings do i need
Hello ed4037, If you are blowing fuses this means that you are drawing too much current check your impedance value on your amplifier it should be 8 ohms to match the subwoofer's 8 ohms of impedance. In addition make sure that you have the proper value fuses. In other words you should not be tuning the amp not to blow fuses, because you should be able to go to full amplitude on your amp without blowing anything. As I alluded to this sounds like an impedance mismatch problem. I hope this helps, Thank you, Shuttle83
May 02, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
173 people viewed this question
Top Jl Audio Car Audio & Video Experts
hoyzee1
Morne Olivier
Jamie Henning
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
