Question about Star Micronics TSP 1000 Thermal Printer
Wizard was interrupted before TSP100 setup version 2.4.1 could be completed
Bypass expired
It is recommended if possible that a ConfigurationReport be printed
from the device prior to performing the following procedure to resolve the fault.
Procedure
1. Remove the'Product Enablement Key' (SIM Card) from the rear of
the device.
2. Press[Menu], then[#], then[1934], and press[OK].
3. Select[Machine Diagnostics] and press[OK].
4. Select[Memory Clear] and press[OK].
5. Enter[1934] and press[OK].
6. Wait for the Memory Clear procedure to complete, and the device to
reboot itself.
7. Complete the'Setup Wizard'.
NOTE: If completing the Fax Setup section of the wizard, the device will
reboot again when exiting/completing the Setup Wizard.
NOTE: In the Fax Setup section,'1/3 Fax ID' is the Phone Number, and
'2/3 Fax ID' is the Name ID.
8. Insert the'Product Enablement Key'.
NOTE: If normal operations are still unavailable, then switch the device
off, unplug from power outlet, wait 30 sec, reconnect power and swi
Feb 10, 2015 | Xerox Office Equipment & Supplies
When I started to install canon printer software LBP 3000 comes error (The Wizard was interrupted before the printer driver could be completely installed) and then (to install the driver at later time...
Try download the printer driver from the Canon WEB site.
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Nov 14, 2012 | Canon LASER SHOT LBP-3000 Printer
Hello, I am trying to install Driver Detective on my computer, however no matter what I do, I keep getting this: "The wizard was interrupted before Driver Detective could be completely installed....
Hi...sounds like an anti.virus program is shutting it down. Try temporarily disabling your anti-virus program and retry Driver Detective installation...DO NOT forget to to start up anti-virus after install.
Hope it helps!
Sep 20, 2011 | Computers & Internet
I can't open mastercook version 3 on PC
Compatibility Wizard
1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Jan 03, 2010 | Sierra MasterCook Deluxe Low Carb...
Wizard was interrupted beofre Driver Detective
you must have removed your hardware wich was connected to your pc.... connect it again and then safely remove it..
Sep 27, 2009 | Computers & Internet
I try most of time to install nero7 on P.C. but the installation not complete. An message come as:- The wizard was interrupted before nero7 Essentials could be complete installation. Your system has not...
did power go out --is system compatible with nero7 --is your disc or nero7 file damaged or corrupt -- did you attempt to reload with same problem
Jul 07, 2017 | Computers & Internet
In trying to install OmniPage SE onto a new computer with the vista operating system, all goes well until I come to the installation of OmniScan SE. I get the message: "The wizard was interrupted before...
Unfortunately, Nuance most likely doesn't have a Vista patch to sort the problem with Omniscan.
The best advice I can give you is to remove Windows Vista from your system and install Windows XP.
Vista is riddled with bugs and incompatibilities with many software packages and has been replaced with Windows 7 which is due to be released soon.
Rather use windows XP until Windows 7 becomes available and save yourself many further headaches.
Let me know if you would like any further assistance.
Best regards,
Graemevm
Apr 28, 2009 | Canon ScanFile OCR Full Version for PC
New software installation Problem
software incompatable with your os version or wrong software for device.
vista has many of these issues,have to spend all day looking for compatable drivers for something youve just bought brand new from shop..
Jan 30, 2009 | Lenovo 3000 Y410 (59012354) PC Notebook
Unable to load Roxio Creator 2009. Message says 'wizard was interrupted, your system has not been modified'. My operating system in Vista Home Premium.
During the installation of DirectX 9 portions of Creator 2009, the installation halts, it perhaps tries to roll back, gives an error....wizard was interrupted ... and cannot be completed.
Resolution
Open My Computer (or Computer for Vista users) from your Start menu.
Go to C: drive -> Windows folder -> System32 folder.
Look for a file called dsetup.dll in the System32 folder.
Rename the file to "dsetupOLD.dll" or delete the file.
Reinstall Creator 2009 and follow the on-screen instructions.
It helped some..
Dec 17, 2008 | Computers & Internet
Star Micronics TSP 1000 Thermal Printer Logo
286 people viewed this question
Top Star Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
ray gallant
Jean DeLauche
Jean DeLauche
Are you a Star Office Equipment and Supply Expert? Answer questions, earn points and help others
