Question about Texas Instruments TI-30 XIIS Calculator
How can i graph x cube-9 on my calculator - Texas Instruments TI-30 XIIS Calculator
For example if you are doing the cube root of 8 (answer is 2)
Type 3
hit shift
Press x of square root key
type 8
Press ans key
Posted on Nov 04, 2009
  • Texas Instru... Master
  • 7,993 Answers
I am sory but the TI30XIIS is not a graphing calculator. If you had TI 83PLUS, TI84PLUS, TI89Platinum, HP39G, Casio FX-9750G, etc. you would be able yo do that in a cinch.
To show you what it looks like, I am inserting two screen captures.
I hope you like them.
Posted on Oct 05, 2009
4 Suggested Answers
  • 7993 Answers
SOURCE: How would you enter the following equation to
To enter the inequation you split it into two inequalities
Graph is as follows
Use [2nd][CATALOG] to access the relaional operators less than or equal, greater than or equal, and the operator AND.
To access the inequality signs scroll upwards from abs( to reach the bottom of the catalog.
Note: You can use t as variable only in parametric graphs. Use x.
Hope it helps.
Posted on Oct 20, 2009
  • 7993 Answers
SOURCE: the calculator doesnt graph two equation on the
The Transfrm application for dynamic geometry is probably active in memory. You must purge it from RAM
  1. Press APPS
  2. Scroll Up or Down (Up is faster) to find Transfm.
  3. Select it and press ENTER
  4. Press the number corresponding to the option Uninstall.
  5. Once the APP is kicked out of memory you will be able to draw multiple functions.
Posted on May 15, 2010
  • 7993 Answers
SOURCE: How do I graph equations
This is the equation of a circle centered on (0,0) and with radius r=3. You can draw it as a conic section.For that you will need the conics application. Look for it on education.ti.com
You can also draw it as two branches: y1=+ square root (9-x^2) and y2=-square root(9-x^2). The two parts may not overlap at the points on the the x-axis, but if you are willing to accept the calculator limitations you will have your graph.
Posted on May 22, 2011
Testimonial: "Solved my problem very well."
Why does the TI-nspire not give complete graphs of cube root and other franctional power functions?
I do not see why it would do that. Maybe you restricted the domain to positive values of the independent variable.
Anyway, my CX CAS has the latest OS version and it draws cube root for positive and negative values of x.
By the way the cube root is made up of one branch only, not 2 like the square root.
Here is a screen capture.
Nov 05, 2012 | Texas Instruments Ti Nspire Cx Cas Graph...
I have a TI-89 Titanium. How do I graph a function containing a cubed root?
For example y=x^(1/3)-x+1. Type this function and then graphing it!
See captured images
Sep 14, 2011 | Texas Instruments TI-89 Calculator
When I try to graph something, I see the graph, but I no longer see the x and y axis. This happened on my TI-89 titanium
Enter a function in Y= Editor, then draw its graph.
While the graph is still displayed Press F1
Press 9:Format to open the FORMAT screen
Toggle the Axes ON
Aug 26, 2011 | Texas Instruments TI-89 Calculator
How do I graph equations like x^2 + y^2 = 9 on my TI84 Plus silver calculator?
May 21, 2011 | Texas Instruments TI-84 Plus Silver...
How do I set up graph lines
in order to give the calculator a function to graph, you will want to enter the y= window by pressing the top left most button on the calculator. nintenman1.gif a menu similar to the one above will open, wherein you can enter an equation for the calculator to graph, such as (x^2-2). On the ti-83 itself, you can enter up to 9 equations to be graphed at once. after that, you may want to go to the window menu, where you can set the dimensions of the graphing plane in both the x row and y column. to view the graph, press the top right most button on the device.
hope that helps :)
Mar 29, 2011 | Texas Instruments TI-83 Plus Calculator
Hi, I wonder how to use a TI89 to graph a multivariable functions's 3D picture. Thanks.
First you must configure your calculator to perform 3D graphics
Press MODE
1.The first line shown is Graph. Unfold the hidden menu list with the right arrow and choose Graph 5:3D
2. Press ENTER to validate.
Now you must define the surface you want to draw
1. Press the [diamond] key then [Y=] to get a list of function names, the first of which is z1
2. Enter the following function (or your own) z1=(x^3*y-y^3*x)/390
( x cubed times y -y cubed times x) divided by 390.
3 Press ENTER.
Graph the function
Press the [diamond] key then [GRAPH]
The graphing screen displays progress in %. When it is finished you will see a weird sombrero.
Hope it helps
Mar 21, 2011 | Texas Instruments TI-89 Calculator
How do I do 3D graphs on a TI-89?
Press MODE
1. Press the [diamond] key then [Y=] to get a list of function names, the first of wich is z1
3 Press ENTER.
Graph the function
The graphing screen displays progess in %. When it is finished you will see a weird sombrero.
Hope it helps
Jul 18, 2009 | Texas Instruments TI-89 Calculator
Graph a cubed root fuction on ti-89
Here it is
[Diamond][Y=] enter y1=(2-X)^(1/3)
[Diamond][GRAPH]
Hope you liked the graph
Mar 17, 2009 | Texas Instruments TI-86 Calculator
How do you set up window range?
or press ZOOM, option 6 (ZStandard).  That instantly resets the window range.
Jan 20, 2009 | Texas Instruments TI-84 Plus Silver...
Cube root
x ^ ( - 1 / 3 )
You have to use parentheses around the negative 1/3.
May 30, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-30 XIIS Calculator Logo
330 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
