Question about Whirlpool GEW9250 Electric Dryer
No heat in a 1 year old Whirlpool ncabrio dryer
Air vent is clear to and including the outside exit vent.
  • 770 Answers
If there is no heat, it has nothing to do with the vent, but everything to do with the element. Yoiu either have a bad element or are not getting power to it.
Posted on Oct 05, 2009
Why is my Whirlpool cabrio platinum dryer leaking water, and taking over an hour to dry clothes?
Is this an older dryer? Long drying times are often caused by lack of good heating or poor air movement through the drum. Air movement depends on a properly turning fan and a clear exit of hot moist air to the outside vent. Check and see if you get a strong blast of air from your outside vent. If you don't, you may have a fan problem, plugged vent, or kinked vent tube. The water leaking could be because you don't have any drying going on due to the aforementioned problems.
Feb 05, 2016 | Whirlpool Cabrio Platinum High Efficiency...
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Whirlpool duet electric dryer leaking water
Check and clean your venting from the dryer to the outside. If it is plugged it will trap the moisture in the machine. Remember heat doesn't dry the clothes without air flow to push the moisture out.
Mar 04, 2013 | Whirlpool Dryers
Thermal fuse in dryer keeps blowing out
Hi Janet Douglas
Check to make sure your vent is clear, this can cause the overheat problem and blow the thermal fuse.
Also check to make sure the blower is not full of lint also as this can cause the same problem you are having happen.
Another thought:
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element and thermal can burn out very quickly.
Please take time to rate me
Bud
Oct 14, 2012 | Whirlpool Dryers
Why does it take two cycles to dry a load. The vent an hose are clean. Cleaned the lint out of the dryer and still takes two cycles
Turn the dryer on high heat and go outside the house, hold your hand over the vent where it exits your house. Is the air flow good or is it weak? Is the temperature warm or is it hot?
If you have weak air flow you have an obstruction, most likely in the blower housing. Check the "bird guard" on your vent outside to be sure it is free and clear. If you temperature is low you may have blown your hi-limit t-stat. You will need to replace it.
If you have no heat whatsoever, it may be the thermal fuse.
Feb 18, 2011 | Whirlpool WED5300S Electric Dryer
My dryer is giving off outside heat and not drying my clothes
check the filter is clear and the access vent from heater fan to tumbler is not blocked - have seen a sock blocking air flow -
drier is only a fan blowing air over a heated element & through a duct or pipe into the tumbler - on exit the air passes a filter and if this is blocked - through passage is obstructed and hot air will escape backwards
May 26, 2010 | Whirlpool Dryers
My dryer heats, but it has to run through two cycles to get a load dry
Check the vent and the lint trap. The vent pipe needs a clear path to exit the damp air. Check for bends in the vent tube as well as anything blocking the opening outside.
Use a brush meant for clearing the lint trap available at most hardware stores.
Nov 24, 2009 | Whirlpool Dryers
I have been getting brown streaks after drying clothes in my whirlpool dryer. they are about an inch long. My dryer is about 12 years old. Is it worth getting new drum seals or ghetting a new dryer?? (...
Try cleaning the entire air vent system of lint first including the exit vent panel (to the outside air). Remove the lint screen and wash it in detergent and hot water. The brown streaks are probably scorch marks rather than oil or grease entering the drum. Good air movement is essential to holding the drying temperature down. Hope this saves that old Whirlpool for another decade!
Sep 23, 2009 | Dryers
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
I have a gas Whirlpool Duet dryer and sometimes the cycle wont complete and the clothes arent dry ( very damp). when i use the timed dry option i ave the same result. last week my washer overflowed and i...
Check your exit vent outside of your house... what you can do is remove vent hose on back of your dryer... run dryer and feel the air coming out of the vent right behind your dryer.. now reinstall your vent line and check outside,,, see if you feel the same or about the same air flow... if your air flow is block, then your heat will not come on regularly to dry clothes... good luck
Jan 19, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
