Question about Honeywell CT3200 5-2 Day Electronic Programmable Thermostat Heater
I bought a honeywell ct3200 and not sure how to hook it up to a two wire system. The wires coming out wall are black and white
  • 308 Answers
If you just have two wires coming from the wall then attach them to the terminals marked R (may say Rc and or Rh, usually has a jumper installed between the two) and W. Hope this helps
Posted on Oct 05, 2009
Bought new thermostat model ct87k but old Honeywell model I have was hook up by black and white wire not red and white , so how do I hook up.
The two wire Honeywell T87 and CT87 is nothing but a switch in a control circuit. Wire color is not important at all. What is important is the TERMINAL DESIGNATION those wires are hooked to. Soooo....take the wire off of the sub base of the old stat terminal marked 'R' and attach it to the new sub base terminal marked 'R' and so on. Wire COLOR means nothing at all in your case.
Oct 04, 2014 | Honeywell CT87K1004 Round Heat Only...
I have a two wire thermostat system. I switched the thermostat from a mercury one to the Honeywell CT3200 with dip switches set for my electric forced air furnace that is 31 years old. The white wire is...
If you look closely at the installation manual page 6&7 it tells you settings to use for your type of system. If I'm not mistaken you will need to back out screw "b" 360°. Hope this helps!
Jun 17, 2017 | Honeywell CT3200 5-2 Day Electronic...
I only have 2 wire from the old thermostat... white and black. where do i connect them?
To R and to W. Probably black to the R and white to the W If your new stat has Rh and Rc you will connect to Rh
Jan 22, 2011 | Honeywell CT3200 5-2 Day Electronic...
Trying to install a Honeywell RTH6400 but I only have a white and a black wire coming out of the wall.
Hook the black wire to the "R" terminal and the white wire to the "W" terminal...
That's all you have to do... then program the t-stat...
heatman101
Oct 14, 2010 | Honeywell FF12HH Thermostat
Wiring with Honeywell RTH6400
I have the same problem. I am Trying to install a Honeywell RTH6400 but I only have a white and a black wire coming out of the wall. Do I have the wrong thermostat. The manual doesn't explain this siutation.
Thanks!
Dec 29, 2009 | Honeywell FF12HH Thermostat
I bought a new honeywell digital t stat, now i have 4 wires coming out of wall for ac to that thermostat and 2 wires off of furnace thermostat how do i hook them all to one thermostat
Tou may ahve a two transformer system. On the sub base of the tstat there is tterminals rh and rc they come with a jumper wire between them. Remove jumper. Hook the two wires from your heat to rh and w. Hook the rest of the wires Red rc yellow to y green to g and blue or black to c. Thats it . Keep in touch and I will walk you thru this. Rus
Dec 16, 2009 | Ruud UBHC Air Conditioner
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if ur are replacing the heater and it was originally 220/240 ur wiring should b ok but to b sure trace the line wire back to breaker panel and look at breaker the white and the black should b hooked up to separate breakers if the white is hooked up to a ground bar usually on the inside side of the panel and the black hooked up to breaker ur line is 110/120 and will cause problems when hooked up. if the lines r 220/240 than red can hook up to white and black to black
Sep 25, 2009 | QMark FBE15002 electric baseboard heater...
RTH2520B Honeywell Programable Thermostat wires
Hi soozankrayg!
Your problem should be pretty simple. (assuming that it is a typical 24volt system) you should hook up the black wire to the "RH" terminal and the white wire on the "w" terminal. Make sure that you turn off the power to the furnace at the breaker or the furnace itself before attempting this. The reason for this is that you can cause a short and either break the fuse at the furnace or burn up the circuit board. This can happen very quickly and is very common when a thermostat is removed.
Jan 28, 2009 | Honeywell Programmable Thermostat Heater
What wires go to what
The colors you have are not standard.
Your going to have to see where the wires connect on your appliance to answer this. find out and post back
Nov 29, 2008 | Honeywell Electronic Programmable...
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
314 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
