Question about Smart Parts Digital Picture Frame
My frame blinks and doesn't show a clear picture any longer. What's wrong with it?
    President:
  • 2,976 Answers
It was either dropped, had something spilled into it or, it needs a battery.
Posted on Oct 05, 2009
The picture frame just turns off after the third photo.
return it to the supplier to check and repair of replace. If there is nothing wrong with it they can explain the issue. The supplier is always the first port of call. It may still be under warranty?
Jun 23, 2015 | Photography
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
Do you need software to have slide show on frame
What make and model digital picture frame?
Jul 05, 2013 | Photography
Picture is blinking and going to a white screen
Mine did this before it died. It would blink, show the eye and then a white screen that says it's loading something, when I kept the power button pressed down. It was the only way it showed it was still alive. I then bought a new adaptor from RadioShack with the same voltage and amp... and it just died. The adaptor got very hot and I now think it's the frame itself. Unless someone knows what to do inside this frame with pictures, I'd suggest taking it to your local, non-store chain, mom-and pop, electronic repair store...
Nov 21, 2010 | SmartParts SP15MW (092566981886) Digital...
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
Sony KV-32S42 (See Description)
It may be a fruitless effort. The main reason this occurs is that the Picture Tube is drawing too much current and the AKB circuit will not let the video circuit diplay the picture. Outside
of replacing the Picture Tube there is no fix.
You can varify this by turning the screen control up. This is usaully located on the HV transformer and is marked. the other location it may be is on the CRT board. It also would be clearly marked. If you adjust this slightly and the picture appears, the Picture Tube is the problem. I'm betting 100% it's the Tube.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony KV-32S42 32" TV
I get "wrong file content" message on my Coby Picture Frame. What's up with that?
clear off all the extra mac filesystem files using a windows machine (make sure you enable "show hidden files" in explorer). I just did this on mine and it works perfectly now.
May 14, 2009 | Kodak EasyShare EX1011 Digital Picture...
Coby picture frame
Jan 29, 2009 | Kodak EasyShare EX1011 Digital Picture...
Displaying pictures Sunpak 7" Digital Photo Frame
This can mean many things. Pictures don't fit, Wrong file type e.g .png .jpeg .gif. Or has no more pictures to display.
Dec 19, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
Smart Parts  Digital Picture Frame Logo
145 people viewed this question
Top Smart Parts Photography Experts
Tony
Are you a Smart Parts Photography Expert? Answer questions, earn points and help others
