Question about Philips DVDR 3355 DVD Recorder
I have a phillips DVDR3350H/37. I moved it and
I have a phillips DVDR3350H/37. I moved it and the television from one room to another now I can't get the video to work properly. When I connect everything up, the video is wavy on the screen and I can't see the menu.
    Sergeant:
  • 195 Answers
Check connections again
Posted on Oct 05, 2009
Tip
REMOTE CONTROL CODES FOR THE INSIGNIA TELEVISION MODEL: 37" NS-LCD37
This information was found on the Insignia website www.insignia-products.com Under the technical information for the insignia television model: 37" NS-LCD37. cablevision-ur2-cbl-cv04.gifaligner.gif CableVision UR2-CBL-CV04
code: 096
charter-digital.gifaligner.gif Charter DIGITAL
code: 0463
comcast-m1057.gifaligner.gif Comcast M1057
code: 0463, 10463
cox-cox.gifaligner.gif Cox COX
code: 0463
direct-tv-rc23.gifaligner.gif Direct TV RC23
code: 10463
dish-network-vip508.gifaligner.gif Dish Network VIP508
code: 720
dish-network-vip622.gifaligner.gif Dish Network VIP622
code: 720
motorola-drc800.gifaligner.gif Motorola DRC800
code: 0463
one-for-all-urc-6690.gifaligner.gif One for All URC-6690
code: 0464
phillips-pdvr8.gifaligner.gif Phillips PDVR8
code: 115
phillips-ph5dss.gifaligner.gif Phillips PH5DSS
code: 115
phillips-ph5dvd5.gifaligner.gif Phillips PH5DVD5
code: 115
phillips-pmdvr8.gifaligner.gif Phillips PMDVR8
code: 115
rca-rcu807.gifaligner.gif RCA RCU807
code: 135
rogers-dct3250.gifaligner.gif Rogers DCT3250
code: 0463
shaw-dct3416.gifaligner.gif Shaw DCT3416
code: 0463
sony-rm-vl600.gifaligner.gif Sony RM-VL600
code: 8043
tivo-hd.gifaligner.gif TiVo HD
code: 0091
tivo-series-3.gifaligner.gif TiVo SERIES 3
code: 0091
on May 23, 2009 | Insignia 37" LCD Flat-Panel HDTV
Tip
REMOTE CONTROL CODES FOR THE INSIGNIA TELEVISION MODEL: 37" NS-L37Q-10A
This information was found on the Insignia website. www.insignia-products.com under technical information for the insignia television model number 37" NS-l37Q-10A cablevision-ur2-cbl-cv04.gifaligner.gif CableVision UR2-CBL-CV04
code: 096
code: 0463
code: 0463, 10463
code: 0463
code: 10463
code: 720
code: 720
code: 0463
code: 0464
code: 115
code: 115
code: 115
code: 115
code: 135
code: 0463
code: 0463
code: 8043
code: 0091
code: 0091
Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
Mar 07, 2010 | Philips 42PF7220A 42 in. Plasma Television
I am getting a "no signal" on the blue screen on DTV mode of my Protron PLTV-3750 LCD. It has worked until I moved it to a different room. The signal is good on other tv. Anything I can do?
First make sure you have your cables connected securely, then try to move your antenna around and rescan your channels everytime you move the antenna.
Dec 01, 2009 | Protron PLTV-37 37 in. LCD Television
MY 60 INCH PHILLIPS 60PP9200D/37 WILL NO POWER
If the front power light does not come on check the fuse in the back of the Tv.
Jul 18, 2009 | Philips 60PP9200D Television
I choose the mode show room and I can move anymore nothing in my
Solved my problem it was not the home mode-it was using the cable cord instead of the av cords. You cannot use the cable (antenna) you have to use the av cords & connect thru the av on cable box & av on the tv.
Dec 13, 2008 | Olevia LT37HV 37 in. HD-Ready LCD...
Removing Insignia 37' TV from Stand
There are 7 screws on the back of the tv - should be a phillips, once you have taken all out pull the tv up. If you figure this out I would be willing to buy the stand off you. I removed mine since moving and thought I did not need and threw it away, now need a stand. Email me at co45lt@gmail.com if you are interested.
Thanks
Oct 24, 2008 | Insignia 37" LCD Flat-Panel HDTV
Tv turning on and off itself
Try "hiding" the remote from the set so that the TV cannot "see" it. Hope this little trick helps...accordianman
Jan 22, 2008 | Philips 43PP9202 43" Rear Projection...
Phillips 42" LCD Mod#42PF722OA/37
This problem is related to two failures, one is the Power Supply Board, another one is the Y-Main Board. Troubleshoot procedures:
1. Disconnect the Vs Power Supply cable from the Power Supply Board,
2. Turn on the tv and check the Vs voltage on Power Supply Board,
3. If the Vs voltage is there, then the Y-Main board failed.
4. If the Vs is not there, then the Power Supply Board failed.
Jan 18, 2008 | Philips 42PF9996 42 in. HD-Ready LCD...
Philips DVDR 3355 DVD Recorder Logo
171 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
