Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Top shelf not cold whirlpool gold side/side
Dude you help me with my dryer a few months ago..I hope that things dont happen in three's but now my fridge is giving me some trouble.The unit is a whrilpool Gold side by side 2001top shelf is luke cold bottem is colder and the freezer side is alittle bit on the warmer side but blowing cold air. I dont feel any cold air blowing at the top vent in the corner of the fridge side, compressor is running and I cleaned off the fins from dust but no change?? can you help
  • 308 Answers
If you can check the back wall of the freezer where the evaporator is. If you notice that it is starting to ice up, (which by your description I'm sure you will), the most likely cause of your problem is lack of defrost. This can be caused by a couple of different things, ie. bad heater element, of limit switch, or the most common bad defrost timer. Hope this helps
Posted on Oct 05, 2009
How do you check the defrost heater on a whirpool side by side?
How do you check the defrost timer?
Posted on Dec 18, 2009
How to replace defrost timer
a bad defrost timer can be checked with a multi meter
Sep 08, 2014 | Whirlpool Refrigerators
Dryer is not working. When I push the stgart button, nothing happens. A few months ago, i noticed that the dryer continued running even when the door was opened.
Hello, Thank You for using FixYa. I will be helping you today.Sounds like your door switch failed.Thats the reason it would not stop a few months ago.Its part # 3406105
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Whirlpool LER4634J Electric Dryer
The dryer screen has a felt lining that has, again, come loose and has detached in one part. I have had the dryer for 6 months and believe this problem should not be happening. What do you suggest?
i agree it shouldn't come apart, but as it goes for the "felt" try to use a fabric softener that goes in the wash, and try to put the screen (lint filter) on the top shelf of the dishwasher, if no dishwasher you can wash it by hand I've used a soft nail brush with dish soap. hope this helps :)
May 09, 2010 | Whirlpool WGD9500T / WGD9500TC / WGD9500TW...
I have a Whirlpool side by side unit (GS6SHEXNS00) and have experienced chronic problems with the icemaker. I have already replaced it twice. It stopped working again a few months ago and I just couldn't...
Sahal_laher, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Sahal_laher), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool Freezers
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
No water going thru washer arms
remove the pump screen and, clean the pump
you probably have broken glass preventing the pump impeller from moving
May 29, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Whirlpool gold makes banging noise
If the refrigerator is working fine the banging noise you hear is the isulation inside the refrigeratior walls that exand and cotract with the change of temperatures. you don t have to worried about it.
Apr 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Jan 05, 2009 | Whirlpool GC5SHEXNS Side by Side...
Whirlpool Gold Ice Maker Quit Working
IF THE FRIDGE IS COOLING AND FREEZING WITHOUT AND HASSLE THEN YOU DONT HAVE A PROBLEM WITH YOUR CONTROL BOARDS.ALSO IF THE WATER IS STILL COMING OUT THE WATER SIDE OF IT.YOU NEED TO LOCATE THE WATER VALVE AND CHECK IF THE VALVE TO THE ICE MAKER IS NOT BLOWN THAT MIGHT BE THE CAUSE OF THE FRIDGE NOT MAKING ICE.
GOOD LUCK.
MOHAMED
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
160 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
