Question about Kenwood VR-7060 6.1 Channels Receiver
Kenwood KRF-X9080D stuck in stereo mode
My unit is stuck in stereo mode, can't get surround sound to work.
  • 4 Answers
SOURCE: Kenwood Receiver connected to my pc
using the Y adapter method (i am guessing you are using just a single stereo mini-jack cable with a mini-jack to RCA adapter) you are only sending a standard Stereo signal to the receiver. Setting 5.1 in windows is just simulating (if using Stereo) or actually mixing 5.1 if you are using analog 5.1 (3 stereo mini-jack cables going to 3 mini-jack to RCA adapters using a 6 channel DVD input). if you have a surround sound audio card i suggest using the Analog 6 channel input by using 3 stereo cables each with their only adapter.
or, if you have a Digital output (Coaxial or TOSlink [optical]) try using that.
good luck.
Posted on Jan 18, 2009
SOURCE: Surround sound not working properly
Hi guys,
Make sure that your sound aka dvd or whatever is set for a DTS (5.1) set your dvd at bitstreem and your receiver to automatic detection. When your movie will start you will heard your Receiver Relay//Mosfet clicking and a Red led will say DTS once you get there you will be able to select your Doldy digital surround the real one.
Ps: if you want to reset your VR-309 to default HOLD the POWER button for 5 sec unplug it from the wall hold it for 5sec while unplugged and replug it will be rested to default.
Posted on Jan 28, 2009
jomabug76
  • 1148 Answers
SOURCE: Music, sound effects no dialogue
MAKE SURE YOU HAVE ALL THE AUDIO SELECTIONS ON UR PS3 CHECK THE BOXES ,,IN THE AUDIO SETUP
Posted on May 15, 2009
  • 4234 Answers
SOURCE: my kenwood krf-v4060d reciever on/off switch is faulty.
The problem is not likely to be the switch itself. The unit is rpobably going into "protect" mode because of a problem internally. Try removing all the cables and try to turn on the unit. If the behavior remains the same, the output section requires repair. The most common failure is the output transistors. Expect a parts cost in the $40-$60 range.
Dan
Posted on Dec 09, 2009
tbreeze47
  • 3083 Answers
SOURCE: Kenwood amplifier 5.1 sound keeps droping out .
You have a component (probably a transistor) that is overheating, or possibly a capacitor going bad. The circuit board will have to be troubleshot, and the bad component identified. Fortunately, heat problems can be figured out by buying some Freeze Spray (Freon), and when the unit acts up, you spray suspected components, slowly...until it works again. This will identify which component you need to replace by unsoldering, etc. I would start in the power supply area, if you can identify it...chances are that's where your problem is. Good luck, hope this helps.
Posted on Apr 27, 2010
Sounds ok but not dialogue...
It sounds to me like you are using the receiver in surround sound mode and the click you hear is the center channel turning off. If you have another center channel speaker, try swapping that for the one you are currently using. If that doesn't fix the issue, then try replacing the speaker wire. If that still doesn't fix it, then the issue is probably inside the receiver and may be either an output transistor that is failing when hot or an electrolytic capacitor that allows too much DC offset when hot.
Oct 10, 2016 | Kenwood KRF-V5060D Receiver
I have a kenwood Auto video surround receiver DR / 409 how to reset it
PDF]KRF-V8030D VR-409 - Kenwood
manual.kenwood.com/files/B60-4593-00.pdf
VR-409. INSTRUCTION MANUAL. KENWOOD CORPORATION. B60-4593-00 (EN) ...on the country and sales area. AUDIO VIDEO SURROUND RECEIVER ...
Kenwood VR-409 Manuals
www.manualslib.com > Brands > Kenwood Manuals > Stereo Receiver
View online or download Kenwood VR-409 Instruction Manual. ... Kenwood Instruction Manual Audio Video Surround Receiver KRF-V8030D VR-409.
Kenwood VR-409 Receiver Repair Questions, Solutions ...
www.fixya.com > Forum > Audio & Video Receivers > Kenwood
Recent Kenwood VR-409 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
Kenwood VR-409 PDF Owner's Manual Download & Preview
www.manualguru.com > Kenwood Manuals > VR-409
Feb 03, 2016 | Kenwood Audio Players & Recorders
Hey,i have a problem with krf5100,when i do speaker custom setup,my RB and LB wont work,they even dont appear to display like L and R .whats the problem?
First of all, the KRF-V510 doesn't support direct powering of the Surround back but it does have a Pre Out to drive externally amplifed Surround back speaker(s).
The indicator for BS on the front panel is NOT an indication of speaker presence. It IS an indication of the INPUT presence of that channel.
During setup you will only see RB or LB ...
Page 17: IF you have something other than OFF set for Surrounds....
Page 17, step 9: AND you select something other than OFF if you have Surround back Speakers attached to the speaker connectors...
.. and complete the rest of the setup properly. You should HEAR the Test Tones on all speakers. If the Surround Back is inaudible you would need to investigate the external amp/speaker combination you're using.
http://images.kenwood.eu/files/images/products/product_id_229/file_category_26/KRF-V5100D_V6100D_ENG.pdf
Jan 02, 2011 | Kenwood KRF-V5100D
Kenwood amplifier 5.1 sound keeps droping out . Pro logic stop working then other sound modes stop working after a while i.e. stereo, Hall etc...
Apr 27, 2010 | Kenwood KRF-V5060D Receiver
My kenwood is only playing sound from the front 2 speakers the center and surround is not working. is there a fuse inside i can change? what do i need to do?
Not a fuse. Go through all the setups and speaker definitions or maybe just find that pesky "stereo" mode switch and reset it to something that allows all the channels to operate.
Jan 22, 2010 | Kenwood KRF-V5100D
Kenwood krf-x9995d surround issue
It's likely the power amp is faulty. However if you can't get in touch with Kenwood, then take it to another repair shop or go back to the other and tell them you can't get in touch with Kenwood and could they have a look at it anyway.
May 27, 2017 | Kenwood Audio Players & Recorders
Kenwood krf v 5300d dolby issues
Thats is a common symptom of a lost contact or simply a cold solder,that the sound sometimes its come sometimes not coming.Just open the back of the unit and look for the speaker connection and resolder it to tighten the connection,so it works normal again..
Hope it may helps you..
Jun 08, 2009 | Audio Players & Recorders
May 14, 2009 | Kenwood KRF-V5060D Receiver
Unable to get sound from tv to output from surround sound
as the tv stations that were being feed into the system were digital and the nput was actually analgoue 2 optical cables are required.
have tv sound and blue ray sound through surround sound when tv channels were changed to analague.
Mar 22, 2009 | Kenwood Audio Players & Recorders
Kenwood VR-7060 6.1 Channels Receiver Logo
179 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
rigger094
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
