Question about Kitchen Ranges
Apartment size brentwood electric range. The oven, 2 timers to the right of the clock and the outlet on front left have stopped working. Clock works, all top burners work.
    Sergeant:
  • 206 Answers
Some of these ranges have two plugs, one for 240 volts for the burners themselves, one for the controls. Other issue, could have one leg of the 240 volt circuit not working, might get some heat, but not full power. Check fuses, just to be sure. In any event, you likely have two circuits: 240 volts for the power required to take care of the heat, and 120 volts for controls, timers, clocks. If only one plug, I'd expect to find a blown fuse within the appliance, or some other problem in the 120 volt circuit.
Not sure of your level of expertise to open up and trouble shoot electrical. Need to understand (1) how to kill power and (2) how to safely test a live circuit (at 240 volts.) Make sure meter is always set to 250 or greater volts, AC.
Posted on Oct 05, 2009
Stoves oven
Most likely control pad is defective
Nov 02, 2017 | Electrolux 30 Inch White 30" Electric...
Setting the clock
To set the time, turn and hold the Timer knob to the clock
symbol = and at the same time turn the Adjusting knob left
or right until the clock shows the time of day. Remember this
is a 24-hour clock. Let go of the Timer knob and it will spring
back to the vertical, oven manual setting.
Dec 05, 2012 | Rangemaster Toledo 90 (Dual Fuel) Dual...
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Feb 26, 2011 | Kenmore 9535 Electric Range
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Apr 05, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Clock on Model F120 stove Serial 53031577
just set the clock as if to clean , just remember to turn oven off in 2- 3 hrs wait 30 min then before trying to open dr.
Dec 17, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Clock,timer and oven does not work on Kenmore gas Range
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Oct 04, 2007 | Kitchen Ranges
CLOCK & OVEN PROBLEM
How Ironic, we have a Moffat Discovery and exactly the same thing has happend, so we are waiting for a new Zanussi to be delivered.
As the clock timer is linked to the oven it will not light when the clock has broken.
Temporary solutions: So I turned all the electricity to the cooker off and left it a while, when I turned it on still the same problem, but after about 2 hours it comes back on, works for a couple of days then goes off again, (always seems to go out when my missus is planning to cook, so wondering if she' got something to do with it, don't tell her I said that though)
Now trying to switch the clock setting to stop or manual, and when it goes off i'll try and see if the oven lights,
HPC
Mar 03, 2007 | Zanussi ZCG7680 Gas Kitchen Range
Kitchen Ranges Logo
178 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
