Question about Westinghouse 78096 Verandah Breeze II Ceiling Fan
Pull Chain has completely pulled out of Fan Speed Pull Chain Control Switch. Can I pull apart the Control Switch and re-hook the pull Chain, or must I purchase a new control switch
    Genius:
  • 1,550 Answers
Go to purchase another control switch
Posted on Oct 06, 2009
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
How do I get a diagram for a 3 way switch
Do you mean 3 speed switch? The question says your fan has a remote! Pull chain switches are different. If you need a pull chain switch call 1-888-830-1326 with the model # of the fan.
Aug 03, 2014 | Hunter 52" Ceiling Fan With Light And...
Hunter 52, fan works but light no longer works with remote or chain pull
mcdevito75 here, Don"t the fan lights work off the wall switch, The chain pull should be for fan speed. Check make sure electricity is going to the fan.
Jul 19, 2010 | Hunter 52" Ceiling Fan With Light And...
Our fan is going in the reverse direction...how do we switch it?
mcdevito75 here, Generally, The Fan switch itself is a pull chain type switch on the fan motor itself, this is a fan speed switch, NOW! also generally the reverse fan swtich is another shorter pull chain switch just about an inch away from the Fan Speed switch or the longer pull chain switch on the fan motor. This reverse switch can also be a toggle type or slide type switch but will be close to the fan speed switch on the fan motor itself.
Jul 18, 2010 | Monte Carlo Dryers
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
Pulled chain to slow down fan speed. Chain came out of the housing. Yikes. What should I do? Perfetually have the fan running or can I take it apart and fix it?
Turn the fan off at the breaker. Is there any chain still hanging out? If yes, buy new section of chain at hardware store. If no, buy new pull chain switch at hardware and replace.
Jul 27, 2009 | Dryers
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Westinghouse 78096 Verandah Breeze II Ceiling Fan Logo
543 people viewed this question
Top Westinghouse Dryers Experts
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
