Question about Toro Lawn Mower With Toro Power Tools
Flat front tire on toro riding lawn mower
Does anyone have experience in pulling off the wheel? it seems secured by a pin that has top shaped like a 'T' and the other end that goes through the whole is curved so it makes it really hard to pull it through. Any tricks to the trade
    Sergeant:
  • 302 Answers
You need to take your pliers and straighten the curved end to remove the pin and then pull the wheel off. Be sure that your bend the pin back to the way it was after you re-install the wheel. hope this helps you
Posted on Oct 06, 2009
Changed rear flat on ariens 42 in riding mower put tire back on now mower will no move any more. worked fine when I pulled it up to take tire off
I feel you have lost the shear pin that goes on your axle. The shear pin goes in the little groove in the wheel It may have fallen out when you pulled the wheel off.There are also safety pins in the belt drive pulleys
Oct 27, 2016 | Ariens Garden
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
Toro 57360 lawn tractor transmission problems
It might have run out lube and seized pull out and check.
Sep 12, 2014 | Toro Garden
Need information on fixing steering on we261 riding lawn mower.
you will have to pull the front wheel steering spindells if they dont have grease fittings and grease them
Jul 17, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
Wheel stuck on shaft
make sure there aren't any c clips holding it on I would use a block of wood and a hammer I have put green slime in my tires that stuff works great it should fix your tire
Jul 26, 2013 | Toro Garden
Remove front tire on lawn mower
Jill,
If the tire has a hole have you considered a Plug?
If thats not an option before you can pull the tire off, there should be a small snap ring holding it in place. please use blocks to block the tires and do the following.
  • Park the lawn mower on a level surface, then place the wheel chocks in front and behind the rear tires.
  • 2Place the jack under the frame at the front of the mower. Raise the mower up and place the jack stands under each side of the frame. Lower the jack until the mower frame sits firmly on the jack stands
  • 3Remove the plastic cap in the center of the wheel by hand; this should expose the snap ring holding the wheel to the axle.
  • 4Pry the snap ring off the axle with the flathead screwdriver. Slide off the washer, wheel and the shim washers from the axle.
    To replace tire follow steps 3 and 4 in reverse order. place shim washers back on and then wheel and then snap ring, etc...
    hope this helps
  • May 29, 2012 | John Deere Garden
    Pulled pin to free roll model 917.271743
    raise seat remove battery and batt box you should be able to see top of transaxle. wash off good with hose, then find where pin meets lever on axle. tap lightly with hammer to the front position. be sure pin is not in lock position
    Mar 11, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Drive system stopped working on our toro personal pace mower.i looked over most components but could find no obvious fault
    check the belt by the engine make sure it did't ride up over the pulley. check to make sure your springs not broken. may wont to pull your tires off to check thew drive pin's. let me know good luck
    Oct 17, 2009 | Toro Garden
    Toro Lawn Mower With Toro Power Tools Logo
    197 people viewed this question
    Top Toro Garden Experts
    Joseph Mueller
    Joseph Mueller
    lnbn1975
    Mike Squire
    Are you a Toro Garden Expert? Answer questions, earn points and help others
