Question about Frigidaire ATF6000ES Front Load Washer
Defrost cycle timer where is it Sides of the freezer are hot
  • yadayada
    yadayada May 11, 2010
    defrost?????
  • 4,070 Answers
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Here's how to test the fan.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Oct 05, 2009
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer started defrosting and the sides where burning hot. I emptied it and unplugged it. The next day i plugged it in again and it froze a water bottle rather quickly but the sides where still burning...
Your defrost timer has stuck to on position, replace timer and all good or locate timer and spray lubricant into the dial and turn it several times with unit off, then try it after several hours, quick fix only but may last several years...good luck...Russ
Aug 22, 2011 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Power to refrig. Front displays show temp for freezer (0) and refrig.(37). Fan running by coils. Neither will cool. Also the compressor is hot but no humming or other noise
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Aug 04, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is frosting up. Have the freezer on the 2nd lowest setting (#2) and everything is hard rock frozen and frost is on the sides of the freezing unit.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";}
DEFROST PROBLEM
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Dec 30, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice forming on back of freezer , refrigerator side not cooling GE modelgss22wgpe bb
You frig is not going through the defrost cycle. Locate the defrost timer and advance it to the defrost cycle.(one click). Empty the freezer and remove the rear panel. See if the defrost heater is starting to get hot. Located at the bottom of the evaporator. If getting hot, replace the timer. If not getting hot, unplug the frig and check the resistance across the defrost timer(should be a closed curcit when cold) and across the heater. If "0" resistance, replace heater.
When replacing the heater alwarys replace the defrost thermostat at the same time. Will save you work in the near future.
Dec 28, 2009 | GE Refrigerators
My coils are red hot through the freezer vent. Is it okay to leave plugged up until I can repair this?
It may cut off by it's self. Your defrost timer is part 13 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?diagramPageId=00002&documentId=M0310055&modelNumber=MSD2454GRQ&productCategoryId=0165000&brandId=3048&modelName=&blt=11 I would turn the timer till the compressor started running again. This should cut the defrost heater off. The timer should stay in defrost mode for only about 20 minutes. The timer may be the problem. Here's an explanation of the defrost. The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
Oct 12, 2009 | Maytag MSD2454G Side by Side Refrigerator
My frigidaire FFU20FC6AW7 is not freezing. sides are cool to the touch and they are normally hot. cold air blowing out about 40 degrees.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
Jul 12, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Both freezer and refrigerator temp variations
in most refridgerator cabins is a air dam at top right of side by side and it could be sticking open and working other times or it could get stuck in defrost cycle due to defrost timer not working properly.defrost timer would be first thing to look to.
Apr 20, 2009 | Refrigerators
Coil is freezing on freezer
Yes, the seal will let outside air into the unit causing the coil to ice up. When it ices up the air cannot blow through the fins in the coil, thus no cold air goes to the refrigerator section.
Dec 20, 2008 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
