Question about RTO Bodyguard T200 Treadmill
My Bodyguad T200 treadmill makes a ticking sound after its been in operation for 10 - 20 minutes. I have had the bushes adjusted by a technician, run the machine for 10 minutes at max, and the motor replaced but it still makes this noise. Any ideas on what is causing this noise?
Ticking sound on horizon t101 treadmill
If you wish to get some details about treadmill repair; visit the site linked here. in the search tab put the world "ticking" and search.
http://electro-medical.blogspot.com/
Jan 06, 2017 | Horizon Exercise & Fitness
How do I lubricate with oil my t200 gfit treadmill? Please show pictures. Thanks
You have to use silicon lubricant not oil. chek the video.
If you wish to get some details about treadmill ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ Treadmill walking belt lubrication
Dec 04, 2016 | Exercise & Fitness
Treadmill gfit t200 keeps triping the breaker out. No blown fuses on the treadmill. Dose anyone know why?
problem in the power cord to the machine
could be loose wire in the plug or switch
call an electrician
Jul 17, 2016 | Exercise & Fitness
Weight limit not exceeding 136
It sounds like it is set to read kilograms instead of pounds,check your manual to set the treadmill to english instead of metric
Jul 30, 2009 | RTO Bodyguard T200 Treadmill
TEKK 2 treadmill motor problems
You lower computer board is bad. are they still in business?? If not it will be time for a NEW treadmill. name brand so we can get parts
Apr 06, 2009 | TEKK Fitness Two Treadmill
Pro-form treadmill belt binds
May need to be tightened www.AtlantaFitnessRepair.com
Mar 27, 2009 | RTO Bodyguard T200 Treadmill
Treadbelt not alligned
Hi, Most all treadmills use the same type of belt tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 04, 2009 | RTO Bodyguard T200 Treadmill
RTO Bodyguard T200 Treadmill Logo
122 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
