Question about Cell Phones
My phone won't charge. when i plug up my phone wit won't charge...i think my charge part on my phone is broken. how do i fix it?
  • 78 Answers
CHANGE YOUR CHARGER PIN
Posted on Oct 06, 2009
My Samsung will not accept a charge
hi Karen.
you could try this,but do so at your own risk.
How do you fix your phone if it wont charge? All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or read up some more at this link.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
or this one.
Samsung will not accept charge Google Search
Dec 12, 2017 | Samsung Cell Phones
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
Recently my samsung galaxy s2 fell on the ground and shattered the screen! A day later the phone just died! I've bought and fitted new screen and housing but the the phone still won't charge or...
you need a new phone i think you broke the motherboard in the phone i did this as well and tried to fix it myself when i took it in to get fixed they said that the motherboard was broken and that i just needed a new phone... good luck look at it and make sure nothing else had been disconnected also look at the charge points and make sure nothing broke off and got stuck in there i know simple stuff... but sometimes thats the problem...
Jan 10, 2013 | Cell Phones
My Pantech Flex wont charge
This happened to mine. Just pop the battery out then put it back in
Dec 02, 2012 | Pantech Flex 4g Mobile Phone - Black at&t
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
I have a jawbone jambox. The charger plug will not stay in the jambox, it just falls right out, therefore, it won't charge. Where can I get this fixed?
Dont know what these people are talking about.. but I have the same issue. Dropped it, now the charger wont stay in. I've taken mine apart, thinking I could fix it myself, only to find that the actual jack the charger plugs into has been broken off the circuit board. Not good. I'm pretty sure it's not fixable, thought I'm trying my best to find a way to replace the circuit board, as it's not very big. Email me if you've found a solution.iamlucasking@gmail.com
Oct 24, 2011 | Motorola Cell Phones
Ambiedabambie@aol.commy phone won't charge
Charger connector to phone worn out, wiggle it around to see if it starts charging.
Not plugged into a live outlet.
Charger broken, replace.
Phone battery failed, replace.
Call or visit your carrier and ask for help.
Jun 16, 2011 | Cell Phones
Lg prob
it is better way if you have warranty then make use of it ...
if not if you are good at opening then open it and just have a look near port ... if you have the broken piece join it by soldering...
if you dont have that broken piece then just take two small wires an d carefully identify the positive and negative in the circuit board & solder it near the port which is used for charging and then cut the pin of the charger and connect the positive & negative correctly to those wires whenever you want to charge ....
else visit the technician he will replace if the spare part of it is available ..
this doesnot charge too much it is affordable so i suggest you to visit the technician....
Apr 15, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Problems when trying to charge my phone..
try soft-resetting it by taking the battery out and then putting it back in and turning on the phone. if the problem persists, you could try a different battery and/or different charger. if that still doesn't work, it's warranty time! call your carrier's cust. service or go into a corporate store and they can give you the number for the warranty dept.
Jan 28, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell Phones Logo
56 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
