Question about Echo Rapid Loader, Trimmer Head
Need to replace the trimmer head cutting line. cannot open the head to load the line. Echo SRM 2400. I know the trimmer head separates but have tried to rotate the line feeding section of the head in both directions but head will not separate. thanks for your help Martel
  • 87 Answers
Did you try pushing down hard and turning @ the same time? that should do it.
Posted on Oct 05, 2009
SRM 2400 trimmer. Why doesn't it start?
Ralph, if you are getting fuel, spark and have compression , I suspect the muffler screen is plugged. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Small Engine Repair Cleaning Carbon Buildup on the Exhaust Port Muffler on...
Echo trimmers and loss of power EXHAUST PORT CLOGGED
Symptoms Repair Of Clogged Spark Arrester On Grass Trimmer
My Aunt Echo PB 2100 Blower with Clogged Spark Arrestor Screen
Apr 17, 2016 | Echo Garden
How do you remove the spool on an echo srm-2100 trimmer
Most units like yours has a tap head feed spool. To get to the line spool, you need to push the spool inward and rotate it to release it. The line spool is spring loaded, hence the need to push it in and rotate it to get it to release. You return the spool to the trimmer head housing after loading new line on it the same way, in reverse. Hope this info helps.
Sep 17, 2015 | Echo Garden
I have an Echo SRM 225 and the trimmer head just throws the line . After bumping it it will not cut the line with the knife on the guard -it just keeps slapping the guard and the knife until all of the...
You are winding the line in the wrong direction. It should be wound on the spool in the opposite direction of the spin of the head during operation.
Good Luck!
Aug 07, 2011 | Echo Rapid Loader, Trimmer Head
I have a Echo Gas trimmer SRM-210 Rapid feeder dual line. I need to know how to remove the entire drum for the string spool? NOT how to re-string but how to replace entire head/spool, as if I was going to...
In your manual under section 12: Line Head Installation. You will do the opposite of what it says here. The key is to LOCK the gear drive so the flex-drive shaft won't turn WHEN you are removing the trimmer head. They use a special tool (maybe you have it). But a small-shafted Phillips screwdriver or the like can be put in the drive hole to lock the gearing up as well. Look for the hole in the upper plate and align with the notch in the drive housing and grasping the entire string head unit, remove it. Here is your manual, see Section 12
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
Jul 17, 2011 | Echo Rapid Loader, Trimmer Head
Echo SRM 200 series trimmer is great. I noticed though this summer once I reel in the new string, a short time of trimming later, only 1 side of the string appears. When I open up the reel, the string is...
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
Jul 02, 2011 | Echo Rapid Loader, Trimmer Head
How do you load the trimmer head... Lost the user manuel
Check out the manual (available under the technical documents section of the Echo webpage, or at http://www.echo-usa.com/documentation.asp?Model=SRM-210&lang=E )and it will tell you how to change it.
Jun 25, 2010 | Echo Rapid Loader, Trimmer Head
Need Help Installing U-Turn Trimmer Head on Echo SRM-210
It is ridiculous, there are a bunch of bolts, and then a multi-fit brochure showing a grid of nonsense.
There are instructions on the inside of the package, however that is how to string the line.
Sep 19, 2009 | Echo Rapid Loader, Trimmer Head
How can I remove Echo 230 SRM trimmer head?
Don't know for sure, but I found manual on amazon, Amazon com echo srm manual so take a look if you want. have a nice day
Jul 21, 2009 | Echo Rapid Loader, Trimmer Head
How to remove trimmer head from Echo 230 SRM?
I know I'm replying to a old post, but this might help others. My Echo GT225 might be similiar. Once u are down to the thread bolt & the round shaft part that spins in ither direction, u need to thread back on the line spool, at lest the botton part of it to hold the thread bolt in place. Then start turn that rounded part that normally just spins, it will start to thread off, as you are thrreading it off you may have to also start threading the line spool part off as well at the same time. After that you will need the tool that takes off the C ring clamp thing that's underneath. I couldn't find any info on this online, I just kept on playing with it until I figured it out, UGH.
Don't know how to install new string on Echo SRM 2400
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 29, 2009 | Echo Rapid Loader, Trimmer Head
Echo Rapid Loader, Trimmer Head Logo
868 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
