Question about Toshiba Televison & Video
Toshiba 35AF44 no power.when i plug ac cord,red light comes on for one second and shut off
  • jlmtv Oct 06, 2009
    i have tried it and still the same ''no powewr''
  • 10,594 Answers
Power supply shut down because protection circuit activated due to problem in deflection circuit and most probably in horizontal section of TV.
Please check Horizontal out transistor that could be shorted and requires replacement.
Do you have schematics of 35AF44 to troubleshoot?
Let me know to provide you more technical info.
CAUTION: Electric shock risk is involve in TV repair so Be Careful.
Posted on Oct 06, 2009
  • 448 Answers
Disconnect all the cables for a few hours then press and hold the power button for 30 seconds.
Next, reconnect the cables to check if the TV is powering ON. If not, then the TV requires service.
Posted on Oct 05, 2009
Toshiba Satellite won't start up when AC plugged in
Try another Cord/Charger to verify the Cord, AC jack. If you plug in the AC cord after starting on battery, does the battery charge? Open Control Panel, Power Options, set to High Performance, Advanced power settings, set Sleep and Hibernate to Never, Adjust Advanced power setting to your preference.
Feb 06, 2013 | Toshiba Satellite L300D-ST3501 Notebook
All lights are green except the third light is red.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
My toshiba r10 laptop wont turn on the green power light to the front is on but the yellow battery light only comes onn when i plug in the power cord to it and it only stays about 2 seconds
Ok here's what you will do
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Tablets & eReaders
The tv suddenly shuts off
flyback on the verge of giveing out on you.. needs a new flyback..
Apr 21, 2009 | Toshiba CF36G40 36" TV
Blinking AC light with/without battery, computer shuts down
I want to try a very simple thing, cause it happened to me, while I am working on my computer , it shut down unexpectedly... cause the processor is working with its full performance and no enough cooling around the laptop. so while I move to other place and also I raise the laptop a little bit from the back to let the fans (bottom of the laptop) works perfectly .
try to open it again and do so.... may be it is a so simple thing that was far from your mind like I was before... good luck
Nov 29, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba 35AF44 Sound on full & will not shut off.
Well, a shorted diode on the keyboard circuit would be likely. When you change out the tactile switches, did you check for any shorts on any of the switches?
Nov 07, 2008 | Toshiba 35AF44 35" Rear Projection...
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Does not power stay on
try this with just the ac plugged in and the battery removed. Sometimes the battery, when fully discharged, can cause the system to shut down.
check your warranty here for Free
Feb 22, 2008 | Toshiba Satellite M35X-S149 Notebook
Will not power up
pull battery and cord. push on / off button for 60 sec. put battery back in and plugg in power and boot up.. something else to try is some one elses battery to boot up in.
Jan 07, 2008 | Toshiba Satellite A35-S159 Notebook
Televison & Video Logo
24 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
