Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Water flow is slow checked lines to fridge and replaced filter what next
  • 4,059 Answers
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
There is also a screen filter in the water supply where it connects to the water inlet valve. It may be stopped up with sediment.
Posted on Oct 05, 2009
The ice dispenser is making very little ice and the water dispenser has very little water flowing through it
Greetings,
I would check to make sure the water line is turned all the way on...then , check to be sure your filter is not needing replacing. (if you have one)..if these check ok...........its possible your water inlet valve in refrigerator needs replacing...Bruce Denton
Jan 17, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have an LG side by side LSC27910ST The water
My fridge was hooked up with a self tapping fridge line. I had two different plumbers/repairmen tell me that if the water flow ever slowed I should switch it to a dual line water shutoff, with one going to the sink and one going to the fridge. I did this and it more than solved my problem. The water now flows way quicker than ever.
Oh and I always had good water flow within the guidelines, as in filling a bucket with the line that goes into the fridge. It was a pretty easy fix that only involved one run to home depot. Make sure to note the size of the line that goes into your sink or even just take that hose with you.
Nov 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water come's out to slow? changed filter! was doing it before i changed filter!
James -
Check to make sure the valve for the water supply is on fully - and not between the ON and OFF positions. If that is ok, the water supply line may have become restricted when the fridge was pushed into position the last time it was rolled out (for cleaning, etc.). The line may have become kinked (usually a copper line problem) or partially crushed (copper or plastic) under one of the fridge's rollers.
You should close the water valve before moving the fridge for inspection. Unplug the fridge. Disconnect the water line at the back of the fridge. Inspect the length of line for evidence of a crush or kink. Replace as needed. Test the flow of water into a larger container before reconnecting to fridge. If close to the fridge output, the valve and line to the fridge is suspect. Replace parts one at a time as needed until the problem is solved. If there is significantly more flow than when connected to the fridge, then the problem is somewhere in the fridge - but outside of the filter - there's little to change or go wrong for a "slow flow rate". It's usually an "all or nothing" deal inside the fridge.
Reassemble, turn water supply back on (check for leaks), plug into power, carefully roll fridge into position (watch the water line as long as possible to prevent crushing / kinking) and test.
Please rate this reply if helpful - good luck!
Aug 09, 2010 | Kenmore 77719 Side by Side Bottom Freezer...
Fridge water filter replaced now flows very, very slow
Hi .. first I would try and eliminate the filter as the problem. Remove the filter and try the water again. If the water flows strong, then the filter is the problem. If the water stills sputters and is low flow, then there is a partial blockage in the internal tubing , or a problem with the supply. If you roll the fridge out to get at the suppl. you could shut it off and disconnect the supply tube from the fridge, then turn the water on slowly to check the flow at the supply. If the flow is good there , then the blockage is internal.
May 03, 2010 | Kenmore 21.7 cu. ft. Side-by-Side...
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Low water flow from "ice magic plus"
Have you tried replacing the inline filter? and if you have remove the filter and place a large bowel next to the water line and open it up and see if water flows from the line, if it flows fast then it's a problem with the fridge if it folws slow you have a problem with the water connection. Check that can get back to me if you need more help.
Avid101
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WATER DISPENSER NOT WORKING
It might be that you have a restriction at the water supply line serving the fridge. Check it for good flow (have bucket and towels handy!) If supply line is good, then move onto the fridge to check the water inlet valve(s). as newer models have 2 or 3 inlet valves, a main water valve for the entire unit, and possibly one each for the ice maker and water dispenser past the main inlet valve (solinoid).
You can check these by simply shutting off the main supply to the fridge from the house water line 1st, and then removing each water line from the supply side of the fridge and seeing if you have water flow from the house to the valve side. If you do, then reconnect the lines to the fridge valves and see if you can get water flowing to the other side of the solinoid/valve when you have someone try to get a glass of water from the water dispenser, etc.
It is possible that there is an obstruction in the lines, by not very likely. Normally it is a failed water valve(s) (solinoid) that causes low flow or complete loss of flow, especially if you've changed the fridge water filter or replaced it with the "cap" which eliminates filtering of the water.
It is that you'll likely have to replace at least one, maybe more, of the fridge inlet water valves. If you have the time, try to zero in on the failed one by bypassing each, one at a time, until you get water flow. That way, you'll only have to purchase just the replacement valve needed to get things working again.
Jul 07, 2009 | GE GSH25JFR Side by Side Refrigerator
Water flow decrease on refrigerator dispenser
You might have calcium deposits in the supply line.You can unscrew the line from the fridge and turn on the water to see if you have good flow. Have a bucket or pan handy. Let it run for a minute. If it checks out ok then the problem might be in the line attached to the fridge. Those usually come off fairly easy. If so take that off and see if its clogged. You can also check the valve where the feed is connected to the main water.
Apr 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
Mar 20, 2007 | Frigidaire FRT15G4B Top Freezer...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
254 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
