Question about KitchenAid Kitchen Ranges
Code comes F5E7. This has happen before after we have ran the self cleaning mode. We managed to get it out of that mode. Please help The oven part will not come on
    Guru:
  • 310 Answers
The oven thinks the door lock will not unlock after the self clean operation. This could be:
1. Door lock motor problem - did the door unlock after cleaning?
2. Unlatch-sensor switch on the door lock mechanism - switch or wiring may be bad, or switch out of alignment. Try opening and closing the door a few times to see if it clears (if it's not locked).
3. Control board not sending the proper unlock signal to the lock motor.
We repair control boards at www.fixyourboard.com.
Posted on Oct 05, 2009
Error code 154 on a bosch oven
The 154 error indicates that the electronic control board that acts as the master control for the oven got too hot. This sometimes happens when the oven vents get blocked. Make sure that there is space between the oven and the wall. Check that the oven is raised a bit above the floor. (The exact clearances may depend on the model.) Next unplug the oven (or turn it off at the circuit breaker). Pull the oven out from the wall and clean the louvers if they are dirty. Check the wiring in the oven for any shorted wires. If the wiring has damage, replace it.
Unfortunately, since this happened in the self-cleaning mode, the electronic control board may need to be replaced. Please add a comment with the model number of your oven, if you would like me to give you the part number you need. The model number is often inside the oven on the door frame. For some models, it's on the inside of the drawer front of the drawer below the oven.
I hope this helps.
Jun 25, 2016 | Bosch Kitchen Ranges
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
Error code f1 comes on .we had just finished oven cleaning
This indicates the oven temperature sensor has failed. This can sometimes happen after self cleaning mode due to the heat, it shouldn't but does. It is easy to check and replace. Here is a link that should help http://appliancehelponline.com/oventempprobe.html
Sep 08, 2010 | Maytag 30" Self-Cleaning Freestanding...
Error message
did u self clean... usually that code means the lock will not unlock,, i would recomment killing the power to it for couple minutes if that doesnt reset it u might need service,, or u could replace that latch assembly or door switches
Jan 28, 2010 | KitchenAid Kitchen Ranges
I'm getting a F2 Error and door locked with flashing and beeping after I ran the self-cleaning mode on my GE Model JTP85 built-in oven.
f 2 code states that your oven temp exceeds 590 w/unlocked door .. the oven tempt sensor will need to be replaced .. hope this helped mm
Dec 04, 2009 | GE JTP85 Electric Double Oven
F5E7 Error
First,
Disconnect the power from the oven and let it sit for at least a few minutes. Then reconnect the power and see if it unlocks.
If not you may need an oven latch replacement.
Mar 29, 2009 | KitchenAid Architect ® II KEBS208S...
Our Oven seems to be stuck in the Self-cleaning mode
Have you tried unplugging it and then reapplying power after a few minutes? Sometimes a power down/up cycle will reset the logic..
Sep 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont turn on.
I tried several times to get my oven to work and nothing seemed to help. After downloading the manual from this site, my husband locked and unlocked the oven door several times very hard and it knocked something in place and now my oven works. I hope it works for you.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
Kitchen Ranges Logo
240 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
