Question about Wolfgang Puck Immersion Blender
Two of the three plastic pieces to hold on the blender broke
Phoned company and was advised that no repairs were possible in Canada. On line request with company got no response.
Purchased new immersion blender........not wolfgang puck
Posted on Oct 06, 2009
Switch on Toastmaster stick blender model 1740 is broken.
Superglue a small tab of cut from an aluminum sheet to the the broken plastic tab. Drill a small hole in the aluminum tab to grab the protrusion in switch housing.
Apr 05, 2014 | Toastmaster 2 Speed Stick Mixer
Broken plastic base for CBL25
FIXYA does not know who might have a broken JUG .
Dec 03, 2017 | Breville CBL25 Moda Bar Work Top Blender
I took the spout of the smoothie plus 600 apart and can't put it back together
When you say you took the spout apart and can\'t put it back together its only 5 total pieces. The spout, the spring, the handle, the dispenser (rubber insert with plastic stem) and the threaded cap which holds the dispenser and handle to the spout.
If you can\'t get the handle to re attach, that does not surprise me. This is very poor craftsmanship. The plastic nobs that hold the handle onto the dispenser tend to break off.
If this is your problem, you can either, buy a new one for $5 plus shipping depending on where you live OR
You can fix the part that broke.
All you would need is a Drill, a small piece of number 14 copper about an inch long and same size drill bit. Drill the handle as close to center where the plastic molded nobs were located that either broke off or worn away. Then drill with the same size drill the stem to the dispenser which has the rubber stop attached. Drill this as close to the top of the stem where the nobs would snap in to hold the handle in place. You are basically making a pined handle, which will outlast the quality of this blender.
NOTE: You want to use a drill bit about the same size as the number 14 copper wire.
Then with one hand hold the threaded cap with the dispenser placed into position through the hole, be sure to put the spring in, small hole to the bottom of the rubber dispenser, pushing the spring and dispenser up through the threaded cap, attach the handle by putting the piece of copper wire in your hole which will connect your handle to the stem of the stopper. The copper should be cut no wider thent the width of the handle, if it sticks out a tiny bit, that\'s ok. The plastic cap will simply be carved out where the copper rubs against it. After that, simply screw the handle cap back onto the spout and screw the spout back onto the blender making sure the two washers are still on the pitcher.
All in all, for someone who is handy, this should take about 10 minutes. I would rate it about a 5 out of ten for difficulty simply because you have to drill straight and centered in the handle where the nobs were. Other then that its easy and if you can have someone help you put the pin in place, it would also make it easier.
If for some reason the rubber stop does not seem to go back into the spout, make sure the rubber didn\'t role up onto itself. Also if the spout drips, you didn\'t either put the spring back in or you didn\'t drill at the top of the plastic stem but some where in the middle, simply ream the hold towards the top where the plastic nobs would stop. Its a square reseated area in the stem. Looking at it you should be able to tell.
As for the spout instructions, you can download the pdf manual at the manufactures website: http://westbend.com/spl6white-smoothie-maker-plus-600.html
Hope it all helps, Its worked for me!
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
In dire need for a lid and power cord for this blender
Power cord is pretty standard for appliances/desktop PCs/printers. I would try the local Goodwill, they all have a wall with cords for every manner of appliance. On any given day, my local Goodwill has them in black and grey. Or any electronics store will have them.
As far as the lid - I'm not sure if you lost/broke the entire thing or just the plastic cap in the center. That Jenn-Air center plastic piece is easily broken. Your local Ace Hardware or True value sells replacement Blender cap inserts. Glass center with aluminum washer/nut that screws on from below. Looks better than original and won't yellow.
Nov 28, 2012 | Jenn-Air JBL800 Work Top Blender
Blender does not spin inside the plastic bowl. The blender works, but does not spin the blades inside the bowl.
mine just broke as well the hand blener is working but the piece on top of the inside lide broke off so as not to make a good attachment with handle where can i geta lid
May 02, 2010 | Wolfgang Puck Immersion Blender
KSB5600BO kitchenAid blender blades broke and l am looking to replace them but I can't find the right parts. Do I need to just by the whole Jar assembly?
You don't need to replace the entire jar assembly. Have you tried to contact Kitchensid. They make high quality appliances and will probably send you new blades for $0.
Apr 19, 2010 | KitchenAid KSB560 5 Speed Blender
I have a BL1900 and the black plastic wheel on the base cracked and broke into a million pieces. It is the part that the glass liquidizer sits on - the collar from the liquidizer 'locks' onto the this...
You can order this part Black and Decker Blender Base Collar Ring BL5000-11
I also had the ring crack and ordered another one. It cracked after just a couple uses. So, even though you can get the replacement part, I'd suggest tossing the whole thing in the garbage and buying a different brand.
May 26, 2009 | Black & Decker BL1900R Blender
Plastic jar broke.
I decided to replace the entire blender and I bought a new one online.
Jan 29, 2009 | Faberware FSB100 Work Top Blender
Need new product
I have a brand new, never used (parts still in plastic, but no box) ULTREX Kitchen Preparation Center model 14008- Blender-Food Processor-Fruit Juicer that you could buy.
Nov 06, 2007 | Blenders
Wolfgang Puck Immersion Blender Logo
523 people viewed this question
Top Wolfgang Puck Blenders Experts
ray gallant
Bill Boyd
Are you a Wolfgang Puck Blender Expert? Answer questions, earn points and help others
