Question about Sewing Machines
On the Performance 2065 sewing machine by Pfaff, my thread keeps bunching up underneath. I have tried changing out the needle and rewinding the bobbing. The problem started mid-stitch which was odd, maybe I bumped a dial or switch. Can you help me?
  • Maria Jolley Oct 06, 2009
    How do adjust the tension to the correct level. I am sewing cotton fabrics with batting in the center for a quilt.
  • 3 Answers
Sewing machines usually all operate the same. You could be using the wrong needle on the fabric, the bobbin could still be loose or unevenly wound. If you're sewing stretch knits make sure you use a needle for that fabric. If use you machine regularly you may just need to have it serviced, also make sure you aren't guiding your fabric too tightly. Check to make sure your tension is not set to loose. That's about all I can think of right now. Good Sewing
Posted on Oct 06, 2009
My thread keeps looping on bottom Have changed tension, needle rethreaded and changed bobbin nothing helps what am I doing wrong?
not sure if this will help you...Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimesthread buching can be caused by something as simple as the tension dial being inadvertently turned.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC ? ' eBay
www.ebay.co.uk/gds/WHY-IS-THREAD-BUNCHING-UNDERNEATH-MY.../g.html..
or you could go to this link and see if it helps you out.. thread keeps looping Google Search
Oct 22, 2017 | Sewing Machines
My Pfaff grand quilter 1200 keeps bunching up the top thread on the bottom side of my quilts. I've replace the needle and thread. It won't pick up the bobbin thread. Could this be a timing problem?
Remove the thread from the machine. (Always raise the presser foot and pull the thread up, NEVER down!).
Install a brand new needle.
ALWAYS RAISE the presser foot when threading.
Rethread from the beginning and verify the thread pathway is correct.
Set the upper tension to midway between High & Low numbers--you may need to tweak this for your particular machine, but this is a standard starting point.
Confirm the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly. It helps if you begin sewing with the needle in the uppermost position.
Test on medium weight woven cotton.
If it is still not picking up the bobbin thread, then it most likely is a timing problem. You can search the internet for web sites and videos regarding sewing machine timing or take it for service.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Nov 21, 2016 | PfaFF Sewing Machines
Hi When I start sewing in my pfaff sewing machine the thread keeps breaking off and finally the needle will break...I tried changing the tension also but not helping.please help.
Consult your owner's manual. First thing to do is verify that it is threaded correctly. This is probably the #1 cause for breaking thread. #2 is most likely the tension being too tight. #3 sometimes is the incorrect needle or installed incorrectly.
Check the suggestions here:
The thread keeps breaking Sewing Machines
Jan 02, 2016 | PfaFF Sewing Machines
Keep getting check upper thread message
You have left threads in the thread path that you can't see or get to without a technical knowledge of the necessary "cleaning process"
Go and see your machine repair man who can show you how to get to the problems areas without messing up the mechanicals even more.
Feb 01, 2014 | PfaFF Sewing Machines
My thread keeps breaking every time I start sewing on my pfaff 4.0 sewing machine. O have changed the thread two times. re threaded the needle six times and ensured the needle was in the correct location....
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
Pfaff 134 thread unravels
try changing the needle--make sure to use every thread guide
try a different thread
check for any burrs on the needle plate or on the bobbin case
clean under the needle plate & in the bobbin area for lint or loose
threads
Aug 16, 2012 | PfaFF Sewing Machines
I have a pfaff 2040 tiptronic and the bobbin thread keeps bunching up and stopping the machine
Here are a couple of solutions to try.
* Re-thread your machine, it may be threaded incorrectly.
* Raise your feed dogs if your machine has this feature.
Note: When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
Dec 22, 2009 | Sewing Machines
Thread is bunching underneath fabric
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
Feb 10, 2009 | Kenmore 15516 Mechanical Sewing Machine
Thread bunching underneath fabric as I sew.
You may need to take off the housing that covers the whole dog mechanism. You will need a screwdriver to do this. Blow out the area around the tension gears and dogs, check for loose or disconnedted parts, and re-oil the gears. Fleece fuzz usually collects where you can't see it. This was the problem with my machine that had the same symptom.
Jun 02, 2008 | PfaFF Creative 7570
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
