Question about Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 Dual Trunk-Tracking Handheld Scanner has message that "all Channels are locked. looked up RS FAQ's on this scanner and it states to enter Function 1 then change from banks off to banks on." When entering the "func" key channels 123 start flashing but when I enter 1 the numbers reappear and nothing happens. Tried "func" key with the lock-out key and nothing happens. Nothing else in the manual on how to rx.
  • Thomas Squicciarini Oct 06, 2009
    Actually I was looking at my
    Pro-95 manual for an older model whereas this problem
    is for my Pro-97 model. When I manually enter all the channels
    in each Bank the top of the message board reads "M401FM 0.00000".
    I have to assume that all the Radio codes that were originally keyed
    in were purged. Will try to reinput and will advise if any problem.
    Tks,
    Tom
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you haven't programmed any frequencies the channels will stay locked out. Get your local frequencies by doing a search for police scanner frequencies. Once you have gotten the information for your area press the "PGM" button on the lower right hand side of the key pad. Input your 1st frequency “xyz.abc” then press “ENTER”.
Press “PGM” key again until you get to an empty channel and then enter your 2nd frequency then "ENTER" again. Repeat as often as you wish to enter more frequencies. When you are done, (you can stop any time) press the "SCAN" button in the upper left hand position and you are in business. You are supposed to be able to choose which memory position you wish to use but I haven't tried to figure that one out.
First press the manual button so you can go through the channels one by one. Then look for a button that has L/O(lock out) push this once for every channel you have a frequency programmed for it, the channel will probably not unlock if there is no frequency programmed to it.
Also see this manual for more details--
Radio Shack Pro-95 Dual Trunk-Tracking Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 05, 2009
  • Rylee Smith
    Rylee Smith Oct 06, 2009
    Hi
    Please try and re-input them and follow the steps if you face any issues.
    Thanks
    Rylee
I have a pro 95 dual trunk scanner & it says all
  • Hi, I can help.
  • You probably have all frequencies in that bank locked out and all other banks locket out as well so you are seeing "All Ranges Locked Out."
  • You should be able to just push the number of the bank you want to have active again and activate it. If you have locked out some frequencies just press "MAN" for manual and scroll up and down through all the frequencies and hit "L/O" and the L/O will change to l/o (lower case letters) indicating the frequency is no longer locked. This has to be done manually for every frequency as there is no "master unlock" function on this scanner.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 27, 2011 | Radio Shack Pro-95 Handheld Scanner
How do I program it for triple truncking?
There is no such thing as "dual trunking" or "triple trunking." Such terms are used by manufacturers to indicate the number of trunking systems that a scanner is capable of monitoring. The PRO-95 is designated as a Dual Trunk-Tracking scanner because it is capable of monitoring both Motorola and EDACS systems. Programming a trunking system in to a scanner is a detailed process that requires a bit of research.
For details on active trunking systems in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Once you have the system information you can follow the programming steps outlined in your scanner's operating instructions. If you don't already have the manual, you can download and print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-95/pro95.pdf
Bill B
Jul 24, 2010 | Radio Shack Pro-95 Handheld Scanner
Pro-95 scanner is locked
Lets see if I can help you.....Turn on the unit, Press PGM, press TRUNK, select group using up or down button, press FUNC, then 6, then press 1 to clear...To program....Press PGM, press TRUNK, repeatedly press mode to select MOT, Press PGM,enter the frequency you want, then press ENTER to store it. If you make a mistake, press CLR to erase....Get your frequencys for your state at www.RadioReference.com ...hope this was helpful......
May 21, 2010 | Radio Shack Pro-95 Handheld Scanner
How do you set Pro-95 to receive police "Viper Channels" Mine, most of the time is static or beeping, Squelch doesn't help. Is there a software program upgrade for this. Located in Mooresville, N.C. 28117...
There isn't a Firmware upgrade for this scanner and I also do not think it is capable of Decoding these transmissions. My Pro-95 gets the beeps and tones also. This model of scanner was one of the last models R.S. produced before adding the digital capabilities.
May 09, 2010 | Radio Shack Pro-95 Handheld Scanner
Clearing out old channels on a radio shack pro 95 scanner
Turn it on, and when "Welcome" appears, press zero, then press one. It will display a message indicating it is initializing to the factory state.
Mar 21, 2010 | Radio Shack Pro-95 Handheld Scanner
Pro 95 dual trunk tracking scanner just stays on channel 3 does not scan up to the other 10 channels
the manual at "http://support.radioshack.com/manuals/ome20-525.pdf" (if you don't have it)
says that you may be in manual mode OR that the channel at 3 might be a "trunk guide", that means that the channel is used to send out digital permissions to the system for each radio in the unit(s) to use a certain freq. when they transmit. good luck!
Mar 04, 2009 | Radio Shack Pro-95 Handheld Scanner
Pro-95 locking out channels
Hi, I would check out this site. These people eat and sleep scanners and should be able to steer you the right direction. They also have a huge database of info,,, good luck with it. Mechanic
http://www.radioreference.com/forums/forumdisplay.php?f=6
Jan 15, 2008 | Radio Shack Pro-95 Handheld Scanner
Pro-95 dual trunk-tracking handheld scanner from Radio Shack
Firstly make sure the "squelch" is set as per the manual (link below) page 26. http://support.radioshack.com/support_electronics/doc69/69487.pdf If that fails I suggest initializing the scanner to factory defaults as below:
Aug 01, 2007 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
288 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
