Hello faeriedew: My name is Roger and I can answer your question. The fuse box ix part of the headlamp switch. If you look up at the light switch you should see the fuses. These fuses will be glass. Please be careful that you do not get glass in your eyes if you pop the fuse out. You can also remove the switch to access the fuses. To remove the switch. locate the release button on the switch. Press the button and pull the light switch rod out of the switch. Remove the lock screw that the rod runs through the middle of the switch. Reverse the operation to reinstall the switch. Should you need further help please just ask. Please rate the quality of the answer you received. Thank You for using Fix Ya. Roger
should be under the dash on the drivers side.
My 1963 Ford irlane 500 fuse box is under the dash on the drivers side. It is hard to see and hard to get to.
