Question about Thermacell 2 Butane Refill Pack
Igniter switch shot??? I have two units - one clicks and lights, the other doesn't click and of course, doesn't light?????
I have an electronic ignition furnace that won't spark. The blower turns on after about 30 seconds from hearing the ignition clicking but no spark. I noticed when I completed the lighting proced
On that unit the induced draft motor must close the pressure switch, and all safeties are proven closed, then that signal is powered to the ignition control board. Then the board sends a spark. Lots of times all that happens and the electrode that makes the spark needs cleaning, or the ground for that electrode needs to be cleaned/tightened. Takes some process of elimination for that one.
Oct 29, 2017 | Heating & Cooling
1988 Trans Am will not start when ignition is turned all the way.
Take a test light to the small wire on the starter and have someone turn it to the start position. If the light lights up and the engine doesn't turn over, I would suspect the starter itself. If the test light doesn't light, try it in neutral and repeat test. If it still doesn't light up, it may be the PRNDL switch or the ignition switch itself.
Sep 22, 2012 | 1988 Pontiac Firebird
2003 Harley-Davidson FXSTDI Softail Deuce Starter just 'clicks' doesn't turn engine over happens on occassion Help
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a possible prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jul 26, 2012 | 2003 Harley Davidson FXSTDI Softail Deuce
Won't start
Switch on head lights or cabin light. If they doesn't come on or is weak, the battery is flat. Ensure that you switch off the lights.
With ignition switched on, assuming the lights on the instrument panel cames on and your immobiliser is deactivated, turn ignition to start. You should hear the solenoid at the starter making a click sound. If not, the battery is flat or the starter solenoid is faulty. If it does make a click sound, the battery could be too low to turn the starter or the starter is faulty. Assuming the immobiliser is working correctly, and the starter tries to turn the engine but it doesn't want to turn, the gasket could be blown and the cylinder filled with water, or the engine could be seized.
Hope it is not the last case. MarioCpt
Mar 06, 2012 | 1999 Toyota Corolla
2001 Mustang GT. Motor shut down on quick acceleration. Won't restart. Traction control light lights up "Off" Making clicking noise. Doesn't reset when ignition switched off or battery...
Hello and welcome to FixYa!
You may just have system failure. As a first course of action, I strongly suggest that you remove the positive battery connector and let it sit for at least 5mins. before reconnecting it. This will reset the system and can get your vehicle back to it's normal operation.
This thing really happens and reconnecting the positive battery connector serves like a jumpstart to the vehicle's PCM (powertrain control module).
Hope this helps and thank you for using FixYa! Have a good one!
Sep 18, 2011 | 2001 Ford Mustang
No light when you open door and it won"t run, turn on the start button and it doesn't work
Check the door switch. Sounds to me like it's shot. To test, remve switch and directly connect both wires to each other. If unit runs and light comes on, then that's the problem.
Jul 01, 2011 | Kenmore Dryers
Dometic Americana RM2852 refrigerator does not work. Has power to it, light inside works and lights at top indicating 'AUTO' mode are illuminated, but refrig doesn't work in any mode. Gas is...
Have the same unit but experience no problems. Sounds like a freon leak has left it inert. You can of course switch from auto to gas and eliminate the auto switch over as part of the problem. You can see the gas flame in the outside access hatch, (or maybe hear it) to be sure it is getting gas. since it doesn't respond in auto, which would also work in electric mode, I think it is the freon problem.
May 11, 2011 | Dometic RM2852 Refrigerator
Need a new starter?
I sounds like a ignition switch
Jul 29, 2009 | 1995 Mercury Tracer
When lighting any burner...the igniter continues after lighting."click, click, click, click, click" and so fourth. Thank you for your time.
My parts list doesn't tell me if that is an auto relight unit or not. But since you say it happens on any burner I'll leave out stuck ignitor switch for now.
Check the house ground wire to the unit and check that the burner caps are installed properly. The auto units read a ground when they ignite so if the burner caps are on wrong or dirty they can cause this.
jim
Jul 27, 2009 | GE 30 in. JGP326 Gas Cooktop
Constant ignition clicking on Dacor cooktop
try cutting the power to the stove for half an hour, see if that resets it
regards
Nov 26, 2008 | Neff 28 in. T2764 Gas Cooktop
Thermacell 2 Butane Refill Pack Logo
141 people viewed this question
Top Thermacell Tools & Hardware - Others Experts
Bill Boyd
Tom Chichester
Are you a Thermacell Tool and Hardware - Other Expert? Answer questions, earn points and help others
