Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Bought a new remote yesterday, programmed and still the same problem. Backed out this morning and the remote would not shut the door. Came home and it opened the door, no problem. Did notice the indicater light was flashing 4 times, but not doing it now.
    President:
  • 3,197 Answers
If you are referring to the LED on the back of the motor unit flashing 4 times, that is the code for door sensors misaligned. Check to make sure the small light on each sensor is lit and not flickering ever so slightly. The flickering is sometimes very hard to see but it will cause the problem you are describing.
Posted on Oct 05, 2009
Bought 02 ford ranger got home next morning won't start theft light flashing theft light. Read manual re programmed keys. Looks and un locked doors no start
You have two options , have it towed to the dealer or a moblie lock smith . Takes special tool's to see what is wrong .
Jan 26, 2017 | 2002 Ford Ranger
Just bought a 2003 grand am 6 cycl.....has been running fine has remote starter as well filled tank on way home from work parked car in garage..Went to use remote this morning..woouldnt start used
do you know if the remote is a after market or factory remote. have you tried to stick the key in the door lock and lock and unlock the door,and when start it. all new cars have have theif module in them ,and if is bypassed it will lock up
Feb 12, 2013 | 2003 Pontiac Grand Am
My 99 eclipse does not start, it has a brand new battery that I bought yesterday but when I turn it off for the night, it is dead and won't start the next morning. Also, when the doors are shut, i
Probably one of the lock switches, the switch you push or toggle from inside the car to lock or unlock your doors has shorted. Try manipulating those switches until the clicking stops. Replace the effected switch. If the doors automatically lock when the car begins moving above a certain speed, it could be that relay has shorted.
Dec 04, 2017 | Mitsubishi Eclipse Cars & Trucks
Universal garage door remote
I have a feeling your neighbor operated their door opener when you were programming your new clicker. Try erasing the memory of your opener and then program the clicker again making sure your neighbors do not operate theirs at the same time. To erase the memory hold the smart/learn button in for 10 seconds.
Jul 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
No sound from radio / now car totally dead
Its you antenna module above your headliner. It controlls your remote for keyless entry as well as your am/fm reception via an amplifier. GM part number is 12233252 for updated and revised version around $100 bucks online.
Jun 15, 2009 | 2003 Cadillac CTS
Garage door remote
It sounds like the lock function has been toggled on. Press and hold the button on the wall control with the lock icon for 3 seconds. This will toggle that function off.
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Mysrerious ups and downs
It sounds like the signal coming from your car remote is quite a bit stronger than the signal from the original remots. Many garage door openers have a sensitivity dial. check your owner's manual as you may have one also. Get back and let me know as there are other things to try
May 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
69 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
