Question about Codemasters Colin McRae Rally 2 for Windows
It start fullscreen turns windowed and the game just stopes, if you enlarge the window screen the games continues playing
Why dark manor game didnot support my monitor risolution
Windows XP
  1. From your desktop, right-click and select Properties.
  2. Click the Settings tab.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and select OK.
  4. Try playing your game again.
Windows Vista
  1. From your desktop, right-click and select Personalize.
  2. Select Display Settings.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and click Apply > OK.
Windows 7 and Windows 8
  1. From your desktop, right-click and select Screen resolution.
  2. Adjust your screen resolution to 1024 x 768 (or higher) and click OK.
  3. Try playing your game again.
Mac
  1. Open up the Apple menu.
  2. Select System Preferences.
  3. Click on the Displays icon.
  4. Select the Display tab to adjust your resolution to 1024 x 768 (or higher).
  5. Reopen your game.
    _
    Try this out it seems to work for some people, if that does not work try this out:
    Switch to Windowed Mode
    If you continue to have trouble playing your game in full screen mode, switch to windowed mode. Under the main menu of the game, select Options, and un-check Full Screen mode (or vica verse if you already have windowed mode on, switch to fullscreen)
    Thanks and I would appreciate a reply if that got fixed or not.
    Good Luck!
Apr 27, 2014 | bigfishgames.com
Tip
Atari desperados 2 cooper's revenge window mode
<pre>
for those who wan't to play desperados 2 cooper's revenge in window mode
note: the resolution must be lower than your window
screen size so you can see win the game starts,,,
1. open the desperados 2 cooper's revenge directory
2. locate directory + \data\configuration\game
3. find settings.xml
4. open it as notepad and find this
"<Attribute name="ENGINE_FULLSCREEN" value="0" type="slong" />"
change the value to 0 for window mode and 1 for fullscreen
hope this helps
by korot.chan
</pre>
on Oct 22, 2010 | Video Game Consoles & Games
Why does the neighbours from hell game won't play?
Using an editor open the file "gameoptions.xml" in folder "c:\Users\<your_user_name>\Documents\JoWooD\Neighbours From Hell
turn fullscreen to false instead of true
Apr 23, 2012 | JoWood Productions Neighbours From Hell 2...
When i play the game it's windowed
What I want you to do is right click on your Test Drive Unlimited 2 desktop shortcut.
Then next to the heading target you will see the path that the shortcut takes to get to the exe file.
at the end of this path leave one space and then type +fullscreen 1
The game should now start in fullscreen mode.
Feb 09, 2011 | Atari Test Drive Unlimited 2
Game doesn't start in fullscreen mode I got windows 7 64-bit
Change your windows resolution before starting the game. 1600x1200 worked for me. 1900x1200 made game start windowed without possibility to expand it.
Nov 10, 2010 | Ubi Soft CSI: Dark Motives for Windows
Cant enlarge the screen when starting to play age of empires 2
its maybe a screen problem you may maybe try it on a other bigger or smaller screen ... or you can pirate the game it isnt illegal if you already have the game
Dec 10, 2008 | Microsoft Age of Empires 2: Age of Kings...
Full screen
What games do you play?
In some internet games you can press F11 for full screen.
Though in most games you have to go through their menu's to get full screen.
In windows the default keystroke for fullscreen in Alt, Enter pressed together.
Though that is not a guarantee either.
Generally how to get full-screen is different from game to game in some sort of settings menu.
For instance I play Last Chaos online and it is automatically full-screen.
When I played runescape online I had to select full-screen at the log in screen.
Sep 17, 2008 | HP Pavilion dv6000z Notebook
Codemasters Colin McRae Rally 2 for Windows Logo
571 people viewed this question
Top Codemasters Video Game Consoles & Games Experts
James Wishart
Tony
Coss
Are you a Codemasters Video Game Console and Game Expert? Answer questions, earn points and help others
