Question about Radio Communications
I cannot get Battery Indicater Light to quit beeping
I have a Realistic Pro 2021, the battery indicater light will no quit beeping, I have put a new battery in, the scanner still is beeping, thanking you in advance if you can solve my problem. Bob Cranston
Hi to all, having read the possible solutions to my problem, I removed the case from the radio exposing all of the inside after a good visual of the components I discovered lots of dust and places around the battery compartment had corrrosion inside the where I would not have seen, after cleaning well with contact spray and blowing the dust out of it I now have a fully restored scanner. Thanks for the advice and have a Great 2008!!!
Bob C..Alberta Canada
Posted on Feb 02, 2008
    Brigadier General:
  • 6,966 Answers
There could be three (3) reasons why the low battery indicator is activated:
1. weak/undercharge/discharge batteries;
2. dirty/corroded/loose battery contacts/terminals; and/or
3. internal fault with the electronic sensing for battery level/state.
Corrective measures would require:
a. replace/recharge batteries. The new rechargeable batteries need at least 16 hours of charging time;
b. clean, scrape, tighten (need to bend a little more towards the battery terminals) the spring/contacts of the battery holder;
c. (on the internal fault) your best bet might be to seek the services of a professional electronic technician since this would need familiarity with electronic components, their circuitry and diagnosis, perhaps a bit of soldering and the use of a DVM.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 01, 2008
  • Louie  Role
    Louie Role Feb 03, 2008
    Hi again,
    Glad to be of assistance and appreciate the rating.
    Cheers.
I have a 53 plate clio and when i put indicater on there is my fog light comes on and when i put my lights on and indicater on all my lights start to flash
Thats got to be fun around law enforcement Eh?, i digress, check relays on directional circuit, see if anything is amiss
Dec 21, 2014 | Cars & Trucks
The charger is on but the charging indicater light is not on
You probably need a new battery. A laptop battery loses about 20% of it charge ability each year and this seems like an older laptop. The break down because the heat generated by the laptop effects the battery's chemical behavior. Try ebay for a new replacement.
Apr 19, 2010 | HP Pavilion ze4145 Notebook
This is about the tw 200 high beam, new bulb still doesn't seem to have any current to the yellow wires. One goes to high beam indicater, which by the way that bulb is burned out, the other goes to high...
If you have low beam then you have power to your handle bar switch, and if you have no power coming from the yellow wire from the handle bar switch,replace it.
Sep 15, 2009 | 2001 Yamaha TW 200
Vivicam 8300s
I've been struggling with the same problem and could not figure out what the heck was goin on. When I would connect the camera to the charger the red light (indicating charging) would come on for like maybe 10 minutes. I could take pics for like 30 minutes then the camera would lose juice. Also, the green battery icon (indicating a full charge) would only stay green for like 1 minute then it would go right to the yellow battery icon (half charge). After a couple of weeks the red light indicater would only come on for like a second. I played around with mine and realized that the battery terminals were not connecting to the power source inside the battery holder. Basically the battery wasn't snug enough inside the battery holder to connect to the power. When I pushe the battery in with my finger the red light indicater would stay on. So I took a little piece of paper (folded slightly) and wedge it in the battery holder and closed the battery holder cover. Hope this makes sense! (And helps.)
Feb 28, 2009 | Vivitar ViviCam 8300s Digital Camera
Radio Communications Logo
215 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
