Question about Dell 924 All-in-One InkJet Printer
Printer can't communicate with computer - Dell 924 All-in-One InkJet Printer
    Sniper:
  • 51 Answers
Hi rcamp3,
you can try these steps:
You can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
Posted on Oct 14, 2009
Lexmark X1190 problem communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
Dec 20, 2011 | Lexmark X Office Equipment & Supplies
My Lexmark Platinum PRO905 does ot print it gives me the message " Communication Not Available, The Printer cannot communicate with the computer"
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug your printer into the power source to reset it. When the printer turns on, reconnect the printer into the computer. Try to print again.
You may also refer to this article (for Wi-Fi connection issues): How to identify a Wireless Communication Problem and Resolution Tips
Aug 09, 2011 | Lexmark Platinum Pro905 multifunction...
Problem communicating with printer message when printing. printer says offline
This could be just a slight communication issue. Try to unplug your printer from your computer. Unplug and replug the printer into your power outlet to reset itself. When the printer powers on, reconnect it into your computer. Doing this usually fixes minor communication issues. Thanks.
Feb 21, 2011 | Lexmark X73 All-In-One InkJet Printer
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Computer isn't communicating with my printer
    computer is not communicating with my printer i unplugged the usb port i and i resart the computer
    Aug 31, 2008 | Nikon COOLPRINT Thermal Printer
    Computer will not communicate with printer
    Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
    Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
    X2250 not communicating
    will i think theirs two posible options why not communicate the printer first not proper installed the printer driver or maybe your connection from the computer to printer will loss contact that why not communicate...
    Nov 27, 2007 | Lexmark X2250 All-In-One InkJet Printer
    Dell 924 All-in-One InkJet Printer Logo
    325 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
