Question about Clarion DXZ838RMP CD Player
1991 acura legend , weird idle ,,,, like up and down
  • themackis_ba Oct 06, 2009
    well it turns out the little bolt is a tricky basterd to get out ,,,, never ended up getting it out ,, but kinda stripped the tip :S other than that ,,, what tools do u think i need to do the breaks and rotors? and is 120 a good price for all four rotors with all 8 break pads ?
  • themackis_ba Oct 08, 2009
    good to no so it should go smooth when i get to it ,,,, how much do u think it will cost to fix a rocker panel lol .. its pretty bad
    Scholar:
  • 145 Answers
A common issue for this car,and usually an easy fix.usually its a result from carbon buildup on the tip of the idle adj. screw.in a simple explanation the pgmfi system is set to measure the amount of air flow passed the conned shape port of the throttle body,with carbon build up it gets false readings and is constantly trying to search for the correct adj. The reapair is to remove the screw clean the carbon off the screw tip and also inside the port where it is removed from with pressurized carb cleaner or brake cleaner bought at any auto parts store. The screw sits in upper portion of throttle body assy.,just above where air intake hose from air filter attaches.Its a large flat head screw,inset about an 1/8 of an inch.from the factory it comes with a protective film over so to make removale easier spray carb cleaner over screw and scrap away thin layer of protective coating.Then firmly unscrew idle screw all the way out,once removed you 'll notice the black sooty buildup on the end of screw.clean well with carb clean until all deposits are gone.Then spray carb clean into port of throttle body(where screw goes)wait about 30 sec or so spray again into port. re insert screw and screw in till it completely seats, then back out 1 1/2 turns.start car and hold at higher rpm to blow out deposits loosened in throttle body(30 sec or so)then let idle.surging should have gone away at this point. good luck!
Posted on Oct 06, 2009
  • Joel Mallory
    Joel Mallory Oct 07, 2009
    Not a bad price. If you were to get my true personal opinion, there are a few parts that i always recommend sticking with factory on and brake pads for honda is one of them.Best quality for that car i promise, and price for them is reasonable,sort of, about 75 for both sets(ft&rr).And as long as you dont have any brake rotor vibration(shaking on braking)i would just do pad replacement,saves on rotor life!As far as tools for front you need a 14mm wrench for lower caliper bolt then swing upwards and swap pads.be sure to lubricate caliper slide pins!!dow 111 grease works great!rears you need a 10mm socket to remove small dust shield on caliper and then two 12mm bolts hold upper caliper to fixed portion,remove those and swap pads,again lube slide pins.
Where is the freeze plug located on a 1991 Acura Legend
more info on freeze plug failure? - The Acura Legend & Acura RL Forum
www.acura-legend.com/vbulletin/.../more-info-freeze-plug-failure-1436...
May 29, 2010 - 5 posts - ‎2 authors
my mechanic told me that my freeze plugs could have failed, i have already searched ... Car 1: 1991 Acura Legend ... Car 1: 94 acura legend ls. anti freeze leak
May 11, 2010
Easiest way to
Jul 17, 2007
Manual transmission fluid change help
Apr 7, 2007
engine block heater?
Dec 21, 2003
More results from www.acura-legend.com
Where is the freeze plug located on a 1991 Acura Legend ...
www.fixya.com/cars/t26009696-freeze_plug_located_1991_acura_legend
1 hour ago - where is the freeze plug located on a 1991 Acura Legend - Acura Cars & Trucks question.
Acura Legend leaking freeze plug Questions & Answers ...
Dec 16, 2015 | Acura Cars & Trucks
Need stereo wiring diagram for 1991 acura legend
Check this 1991 Acura Legend Stereo Wiring...
Hope this helps (remember to rate and commene t this answer).
Jan 21, 2011 | 1991 Acura Legend
1991 acura legend idles fine forever but driven for a short distance overheats and overflows coolant tank, also noticed the fans don't go on. thermostat has been replaced.
Legends are notorious for blowing head gaskets- the most obvious signs of a BHG (blown head gasket) are:
White milky substance on the bottom of your oil cap
white sweet smelling exhaust
a surging idle when the car is started cold.
Have a mechanic run a compression check on all 6 cylinders- this is the most sure fire way to tell what the problem is.
If all cylinders are good to go- check the hoses going to and from the heater core- these sometimes crack and **** in air which will create problems.
Water pumps for this vehicle are recommended from acura to change every 60000 miles so that could be your issue too.
Oct 19, 2009 | 1991 Acura Legend
D drive blinks 1991 acura legend
One of your redundant magnetic speed pick-ups are bad. Probably a couple hundred bucks service from your dealer. Worth it. I also had a low idle problem when this happened; car would die at low rpm. New mag pick up fixed that also.
Jun 24, 2009 | 1991 Acura Legend
The Brake Light Sign Wont Turn Off.
Have you checked the brake fluid level. It might have a float switch in the master cylinder.
Mar 24, 2009 | 1991 Acura Legend
How to change front pads on 1991 acura legend
try autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
Mar 20, 2009 | 1991 Acura Legend
My 1991 acura legend sqeaks when the engine is on.
the belt is either too tight or too loose. it may need to be changed
Dec 06, 2008 | 1991 Acura Legend
Engine runs really hot, and engine light comes on while in D4
I had the same problems with my Acura Legend. On the problem with the running hot and the idling up and down, your cooling system is low. Fill your cooling system start it up and look for leaks, steam, or etc. repair and refill and your problem should be cured if the cooling system is full. At this time i'm working on the other problem. Good Luck
Nov 14, 2008 | 1991 Acura Legend
Slow going from idle position
first scan the PCM for trouble codes using a hand held scanner, Then repair codes by replacing failed sensor as needed. If no codes are present then try replacing the idle air control motor.
Aug 24, 2008 | 1991 Acura Legend
Clarion DXZ838RMP CD Player Logo
155 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
