Question about GE Refrigerators
GE refrig/freezer dispenser makes ice, but no dispensing of water
GE Refrigerator-Freezer ModelGSS20IET, 20 cf, suddenly stopped dispensing water but continues to make ice and dispenses both cubes and crushed. I emptied all the ice cubes out of tray, 2 hours later was able to get water, then overnite no water again. What can I do to fix the problem.?
  • GE Master
  • 1,606 Answers
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Posted on Oct 06, 2009
No water or ice coming from the dispenser, ice is being made. Cannot change the freezer temperature
Fix your GE refrigerator door ice and water dispenser ...
? 18:47
www.youtube.com/watch?v=8yNWbNaNCOA
Oct 20, 2013 - Uploaded by StewTube
Fix your GE refrigerator door ice and water dispenser and save ...it makes ice but no water or ice come out from the dispenserAnd if it's the ...
Oct 24, 2015 | Refrigerators
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Nov 26, 2013 | Star Manufacturing GE Profile PFSS5NJX...
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
335 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
