Question about Echo Pb - 413t Backpack Blower
Wont start, carb is clean will start with ether
  • 437 Answers
It sounds like you have a clog somewhere. Fuel filter in the tank may need to be replaced. The diaphragms in the carburetor may not be as flexible and need replacing. You may have a hole in a fuel line not allowing gas to flow or introducing air to the system. Good Day.
Posted on Oct 07, 2009
2001 evenrude e225 will not start normal but will with ether
Do not use Ether on that engine!!!!!!!!!!
Right now the carbs are gummed up and need cleaned. Ether can blow your motor. You can get some throttle body cleaner or take it in and have carbs cleaned.
Just don't use ether
Sep 14, 2014 | Cars & Trucks
Ran snowmobile out of gas now wont start
try a couple of shots of Ether to get the Air out of the Line between CARB and Tank, seen it a few times also it will clean out the Jet in the Carb , put some Injector Cleaner in the tank to get rid of Varnish IN the Carb should take a few tries but within Half hour should run like New
Dec 17, 2013 | Cars & Trucks
I have a coleman powermate 6250 generator it get gas and spark and oil is fine but wont start
Lets see, Do you have any ether or old school lighter fluid? If you use ether spray a little into the air intake just before you pull the cord for a start, if it starts you have a carb problem. Same for the lighter fluid, remove the spark plug and squirt a small amount down in the cylinder, again if it starts you have a carb, probelm. Take the carb. off the engine take note of the rods and springs, take a picture get it in good focus so you can put it back together. Take the fuel bowl off the bottom of the carb and clean the jets and all see if that will help.
Feb 27, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
I have a 6 HP Ariens whipper snipper on two 18" wheels, it is about 5 years old and ran perfectly since new with no maintenance, this year wont start. fires but will not run. changed the fuel and plug...
Check to see if fuel is leaving the tank, the internal screen might be plugged up. Check the rubber fuel lines and if provided the in line fuel filter for flow. Don't always trust carb cleaners and compressed air to clean a carb., you might have to use a steel wire from a wire brush to open the jets and passages.
Jun 22, 2009 | Toro Lawn Mower With Toro Power Tools
Wont start
Hello;
If it starts with ether then you have spark, compression, and air. All you need is fuel. Make sure that you have fuel at the carbs and that the fuel is flowing to the cylinders. Check that the petcock is open and free of debris. Hope that helps;
Thanks;
Rich
RPM Northwest
May 19, 2009 | 1977 Suzuki GS 750
5hp b&s mtd chipper wont start
defiantly the carb but its not bad - clean / soak it with some seafoam and blow out all the holes. its just clogged and isnt getting the fuel/air mixture right.
Mar 30, 2009 | Heavy Machinery
New battery re-charged but still wont fire
Check for spark
If yes, it is getting FIRE, just needs AIR and FUEL
Give it a 5-second shot or two of Starting Fluid (Ether) through the Air intake (filter) and try to start
Does it kick and run really fast and then stop?
If not, pull the plug, clean and check for GAP of 2-3 matchbook covers. Retry. Does it run (or try to)?
If it does, Now we have to look at Clogged air or fuel filter or water in line(s)
Remove air filter. Try ether again. If it starts and runs, replace or clean air filter. Done!
If not... Replace AIR filter and Drain fuel into metal or Glass jug, take off fuel filter, open and drain fuel bowl. Replace fuel filter, refill tank, prime, give it a shot of ether and try again. If it runs, Done!
If it still will not stay running, but you can coax it by giving it a blast every 5-10sec, it could be linkage, stuck choke, throttle plate or jets. Give carb a good cleaning, check throttle plate (in carb throat between it and Air Cleaner) and.check Choke. Try again.
If it still will not run, take to mower mechanic.
Mar 26, 2009 | Garden
Stihl Super Wood Boss 028AV sputters but won't run
sounds like the fuel pump is bad in carb get a carb kit and rebuild it and check the fuel line from carb to to the filter in tank and if that is a two stoke eng with oil in gas do not run on ether will most likely burn up eng
91 yamaha fzr engine turns but wont start
the floats in the carb are stuck. you can try lightly tapping on the carb with a screwdriver that should do the trick.
Mar 10, 2009 | 1991 Yamaha FZR 600
Blaster wont start
Hi, If it starts on ether, then the plug is probably not too bad, spray your premix in instead and if fires OK then your carb is clogged, you can start with the float valve, open the drain screw on the float bowl and make sure it is filling, if it is, then its probably the jets or vanes are lacquered from sitting and they simply must be cleaned. Air pressure and a carb solvent works good when cleaning but other than that no magic. Good Luck, this should Fixya!
Feb 28, 2009 | 2003 Yamaha YZ 125
Echo Pb - 413t Backpack Blower Logo
122 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
