Question about StarTech.com StarView SV211K 2-port KVM Switch
I need ster view key codes oct2009 - StarTech.com StarView SV211K 2-port KVM Switch
  • david waite May 11, 2010
    which area?? eg 54 01 or 5a 01 or 5c 01 let me know and will send codes
The sterring on my 06 tiburon locked this morning the key works but the sterring wont budge
theirs a steering lock pin that can stick or break locking into tab sometimes it can free itself if you try moving wheel side to side and try starting it
Jun 20, 2016 | Cars & Trucks
I need a Sterring colum for my 1987 dodge ram 50, someone tried to steal it and busted the key itinial and I need the entire sterring colum.
You can order one through the dealership(pay a small fortune) or auto body shop. If your not worried about the color, call around to the junk yards, they may have one in a truck there. You can also check on-line at auto junk yards. cheaper than the shops, color is not a option there most times. hope this helps
Feb 23, 2011 | 1987 Dodge Ram 50
I can not turn my ignition switch i turn the steering wheel and it lock up on me
Wheel pressure on the sterring column will prevent the key from turning to start position, Try turning the wheel hard to the left to release the pressure before turning the key to start . If that doesnt do it then try to the right.
Before turning car off make sure the wheels are straight or take your hands off of the sterring wheel before you turn your key to the off position.
Lots of luck Jack
Sep 17, 2010 | 2002 GMC Sonoma Extended Cab
How to unlock the sterring wheel? the dash signs
whats the problem? key won't fit, wrong key, key cylinder distoryed? security light-on?
please explane
Sep 12, 2010 | 2003 Oldsmobile Alero
I have a 2003 Jeep Liberty with a locked sterring wheel
Turn the wheel while turning the key will unlock the wheel wiggle the wheel while turning the key.
Oct 20, 2009 | 2003 Jeep Liberty
Stirring colum is locked
wiggle sterring column back and forth while turning key. You can also take shifter and wiggle up past park
Aug 27, 2009 | 1998 Pontiac Sunfire
2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Apr 02, 2009 | BoxWave Corporation 2007 Honda Civic...
Replacing the Ingition Switch
you have to take the steering wheel off the take all that assembly behind the sterring wheel apart then take the sub dash off and take two bolts off between the sub dash and dash then right behind that should be two copper looking pises that fit together and pull that metal sterring collomn out the it chould be right there bhing you key hole screwed in it is a white relay looking piece
Aug 06, 2008 | 1990 Volkswagen Fox
StarTech.com StarView SV211K 2-port KVM Switch Logo
102 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
