Question about Mitsubishi WS-55511 55" Rear Projection Television
Yellow, blue and green ghosting of picture. Convergence mode will not allow realignment of the red and blue lines
  • 336 Answers
Hi,it sounds like a light engine problem.Lcd Technology uses 3 chips blue,green and red that create the image ,when they start to fail color discoloration will occur.If it's an Dlp pay attention to sounds of buzzing,whirling and high pitch sounds because it could be your colro wheel.
Posted on Oct 05, 2009
Replaced convergence ic's and picture is good but still no blue color to adjust in the convergence mode. the blue bulb is lit in back.
You may have pressed a wrong button when in service mode---it allows among other things to turn individual colors off like Blue--to make it easy to adjust red to green first.
Also take a look with set on into the Blue lens to make sure you have a image and it does not look like a blue flood light.
a last note: if you tampered with the lens (they have a wing nut on side that allows them to be turned you may have on the blue turned the lens so far there is no focus---for that lens--Did you?
May 30, 2012 | Samsung HCN4727W 47" Rear Projection...
My has a double picture with a red ghostly picture in the background. Any information on how to fix the problem? I have changed the cables, viewed the different colors, tv input, and looked over the menu....
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergnce select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the curser (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.Please run the convergence feature on your TV. Its giving you duble image because the red, green, and blue guns are disaligned. By running convergence it will realign the guns properly. You need to run the convergence feature at leat onece a week. Please note this is only for CRT rear projection tv's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to. Please refere to your tv's manual on how to do converegence and how to overlap the crosses because every CRT projection tv is different.
Good luck
Oct 15, 2010 | JVC AV-56WP30 56" Rear Projection...
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Green & Blue Ghosting Convergance problem
Odds are real good that the cooling fluid in the green and blue picture tube assemblies has become contaminated. You can tell by looking down into the lenses with a flash light. Funny thing is the red never gets contaminated because whatever organism is causing the problem can't survive in red light. BTW this may still not solve all of your convergence problems but when the colors are so badly diffused the convergence sensors for flash focus can't lock onto the beam landing.
Jun 01, 2009 | Samsung HCL473W 47" Rear Projection...
Toshiba 50H72 have blue and yellow ghosts
Sounds like your convergence circuit went out. It lines up the red,green and blue picture tubes so the colors are lined up. Usually these TVs all use the same type of IC chips called "STKs" both usually get replaced along with any resistors etc.. around these chips that may have burned up. Depending on who fixes it could be around $300-400 parts and labor.
Rustym62
http://www.the-tv-dude.typepad.com
Apr 26, 2009 | Toshiba 50H72 50" Rear Projection...
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Rca convergence- HELP!!!!
replace the converg pcb inside the tv and realign the picture
Aug 22, 2008 | RCA Televison & Video
RED GREEN BLUE CONVERGENCE IS OUT.
What is your Chassis # ? And convergence problems can be some of the most hard to realign. You may need to replace amps.
Jan 08, 2008 | RCA P52926 52" Rear Projection Television
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
May 21, 2007 | Toshiba 43H70 43" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
204 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
