Question about Kenmore Washing Machines
Kennmore washing maching Model 11026722693 stop spinning out water ....
    President:
  • 1,937 Answers
This is a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26722693
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
It also has a troubleshooting guide.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
You can also use the following illustrated guide to see how to access the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't drain or spin, the problem points to the timer.
Posted on Oct 05, 2009
Why does a kennmore washing machine work during the final spin and the water input does not stop?
does it only final spin? would say bad water inlet valve but should do the same in wash cycle also??
Mar 07, 2015 | Washing Machines
Kennmore model 110.98575120
Sears paid repair service
1-800-827-6655
Feb 14, 2018 | Kenmore 88732 Top Load Stacked Washer /...
Kennmore washing machine Model 11026722693 water level overflows and won't stop filling....
Unplug you washer, if water still runs into you machine, you have a bad water valve. If it does not your selector switch is bad. This is the switch where you set the size load you want to wash. If you will go to www.partselect.com This is their part number PS342529 for your part. enter it in the box and this will bring up the part you need. From there you can order it. Good luck.
Oct 22, 2009 | Kenmore Washing Machines
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Admiral washing maching model aav7000aww
Hello donerehart
You said, water and spin cycles are fine, but won't agitate... what can i do?
Sounds like the timer in the dial will not progress!
Sep 05, 2008 | Admiral AAV7000A
Kennmore 22442
last belt drive kenmore came out in 1986..so doubt you find a belt on it unless you have a calypso model..if you have pump out but no spin motor to gearcase coupling is probably broke
May 05, 2008 | Kenmore 22442 Top Load Washer
Washing Machines Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
