Question about Kenmore Kitchen Ranges
Need to remove the oven door to re-attach the hand;e
Need to remove the oven door to re-attach the oven door handle...only problem is I can't figure out how to remove the door
    President:
  • 1,304 Answers
If its a kenmore,,,,,,
try pulling the door open half way tghen lift staright up
Posted on Oct 06, 2009
Model KEBC277 Kitchenaid oven - I need to remove the upper door, but can't figure out how to unlatch the hinge
there will be two hinge latches that you flip to stop the door from closing. This will allow you to push the door in and then pull out the bottom. I do not suggenst using the handle as it may cause damage. use one hand on either side of the door, push the door shut and then lift up a bit and pull the hinges out of the holes.
Oct 26, 2011 | Ovens
I got the screws off for the door handle on the ACO1860AS Microwave but the handle will still not come off. Is there another mechanisme or hidden screw that needs to come out?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
From the service manual:
Door Disassembly
1. Disconnect power to oven and remove oven door,
(see "Door Removal" procedure).
2. Pry away choke cover, by placing a tool in the upper
right corner of the door and gently prying outward on
the choke cover. Continue to work around the door
casing until choke cover is completely loose.
3. Slide latch assembly upward and to the left to
release plastic tabs from door frame. Once latch
assembly is loose the spring may be disconnected
from the door frame.
4. Remove screws securing door handle and door
frame to door panel.
5. Remove door frame by releasing tabs around entire
door panel.
Remove door handle by placing a hand on door panel
next to the top of the door handle. Twist door panel
towards the inside of door and pulling on the top
portion of the door handle in a quick jerking motion.
NOTE: When replacing door handle, the bottom portion
of the door handle must be inserted first.
You can find handy exploded views and order parts by model number here.
Apr 18, 2010 | Amana ACO1860 Microwave Oven
Door Handle snapped off
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 09, 2009 | Maytag MMV5165 Microwave Oven
Trying to replace the KHMS155LSS3 handle...
To replace the plastic handle on the KitchenAid KHMS155LSS-3 you pry open the door cover from the inside to release the upper tangs (~10). I used razor blades wedged between the tang point to hold them disengaged. Pull the front cover off the door starting from the handle end. Once the top edge is free, the bottom can be remover. See Pitcures.
Repeat the door cover removes with the handle attached from the front after you lift the tangs._828.jpg_829.jpg_830.jpg_831.jpg
Jul 26, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Oven door handle (right side)came loose
If you put the door at a 45 degree angle on the hinges, it will lift right off. Then once on the ground, it should be easy to remove the screws of the inner panel and expose the screws that the door handle attaches to.
Mar 13, 2009 | Maytag MER5555Q Electric Kitchen Range
Door handle replacement
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 13, 2009 | Whirlpool MH7140XF Microwave Oven
Loose Door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Sorry, but I can't be more specific on non-US models.
Hope this helps!
Jun 17, 2008 | Neff B7740N0GB Microwave Oven
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 07, 2008 | Microwave Ovens
How do you replace a broken handle for a GE Spacemaker II microwave?
On some models, the handle may rotate into and unlocked position then lift out.
Mar 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchen Ranges Logo
1,065 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
