Question about LG Flatron L1750S 17" LCD Monitor
Power saver Hi Poser saver keeps coming on and cannot get menu to display to reset the LG Flatron monitor.
  • 2 more comments
  • Donna Cowen Dec 23, 2007
    Power saver stays on can't get out of it. Please advise.
  • mrspink Jan 05, 2008
    cant get my screen out ov power save either tried restarting but nothing
  • Ravis Jan 19, 2008
    I have the display saying "Power saving mode" and nothing else.
    the model is FLATRON L 1717S, six months or so old
    I have tried switching off and disconencting the wires, I was told this might clear the cache, but to no avail.
  • Anonymous Mar 25, 2014
    When i changed the power saver option to On, display isint working.
    Problem Solver:
  • 16 Answers
This problem is showing when the main PCB of the monitor failed. Mr. Ravis not to worry you have warranty, contact the LG service provider in your area. They will change the PCB. check this link to get the service center info
Posted on Feb 09, 2008
Power saving mode displays again and again while i turn on monitor. Also f-engine change node automatically.
right click on the desktop -- properties -- screen saver -- power -- turn off monitor select' never'.
Apr 16, 2010 | LG Flatron F700P 17" CRT Monitor
Monitor Display Messages Not Viewable
You may have components (capacitors) failure in the power supply circuits which will cause odd symptom.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Apr 13, 2010 | LG 22" FLATRON LCD Monitor
LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Dec 18, 2009 | LG Flatron L1750S 17" LCD Monitor
Analog power saving mode
If its going to analog power saving mode, that is what its supposed to do when it does not get a recognizable connection from a computer vga port. I would suggest coming back on with some more information about your computer and suggest testing another screen on your pc.
Oct 31, 2009 | LG 22" FLATRON LCD Monitor
LG Flatron W2234S Monitor Monitor goes black
Ahh the same thing has happened to my monitor! Mine unfortunately is 1 month over warranty. Apparently this is a common problem with this model!
Oct 29, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
After starting, my monitor displays "power saving mode".
Go into the menu and reset the monitor to factory defaults.
Aug 28, 2009 | LG L1915S 19" LCD Monitor
I have a LG Flatron 22", LCD monitor, model is W22345. dilemma: after sleeping the computer for the night, as I have been doing for the past 8 months that the computer and monitor has been in my owne
Check the video cable,replace them, and if didnt work, try to reset the config stored on the settings of the monitor (usually by menu).
Some electronic problems could do the same simptom. check the manual for hints.
Good luck
May 23, 2009 | LG 22" FLATRON LCD Monitor
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
Stuck in power saver mode
Go the desktop, right click with mouse and select properties (if it XP) then it will open Display properties --> there you need to go to Screen saver and then to power option
Disable any power off mode on/ Sleep mode. It will solve your problem.
Please rate the solution. Otherwise let me know for further assistance.
Nov 03, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
LG Flatron L1750S 17" LCD Monitor Logo
156 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
