Question about GE Spectra JBP78 Electric Kitchen Range
What is a f7 - GE Spectra JBP78 Electric Kitchen Range
  • GE Master
  • 3,361 Answers
Can be either a stuck keypad and or a bad electronic oven control. Try pressing all buttons several times each to clear. If it does not clear the EOC is bad.
Posted on Oct 05, 2009
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
Receiving F7 error code while cooking turkey model # GLEFM397
FIXED GE Profile Oven F7 error messages - ApplianceBlog
www.applianceblog.com/.../2655-GE-Profile-Oven-F7-error-messages
Jan 13, 2006 - 10 posts - ‎2 authors
My GE Profile built in convection/thermal wall oven constantly flashes F7 errormessages. ... Three of my neighbors and I have the same GE profile double oven (new home development) and we've all have the same problem as you described-F7. ... GE Oven F7 error message solution. LG Electric oven not heating. F7 error code
Jun 9, 2015
FIXED Kenmore Double Oven error code F0 and F7
Aug 31, 2010
More results from www.applianceblog.com
Nov 14, 2015 | Frigidaire Kitchen Ranges
I've tried pressing fn and f7 at the same time and it won't work, neither will any of the other suggestions. And my computer keeps saying that the touchpad is enabled. Is there anything else that I can do...
Try hitting just the F7 key only. I had an issue with an HP Mini laptop and was hitting the Fn and the F7 key and found the key combination didn't work when I pressed both Fn and F7. But it did work when I just hit the F7 key (even though "F7" was written in blue, the same color as the Fn key, it turned out that I didn't need to press Fn and the key for F7 to gain the functionality of the F7 key. HP tech support informed me of that when I called them due to a similar issue I experienced a while back).
Try to hit F7 alone. That may help you out.
As for the touchpad, it should be enabled. (Unless you're using a different pointing device and want it disabled). There are options where you can turn off the touchpad on start up, but I would advise against doing so.
Dec 28, 2010 | Acer Aspire 5315 Notebook
HI.... WOULD YOU PLEASE HELP ME TO RESET P/M ON PANASONIC COPIER 7728 . I DONT KNOW HOW TO ACCES THE SERVICE PROGRAM..... THANK YOU .
just press "user preset" "original size A3" and "3" simultaneously to enter service mode and the display will be "F1"
to reset the p/m, you should change the value of F7-c22 and F7-c26
go to F7 mode(press 7 to move to F7, then press start)
press "2" "2", then start
press "0" to reset the value of F7-c22, then press start
now press "2" "6", then start
press "120000" to reset the value of F7-c26 (this counter is countdown so it starts with highest count)
press start
press stop to exit F7 mode
press "user preset" and "stop" simultaneously to exit service mode
that's it
May 21, 2010 | Panasonic Office Equipment & Supplies
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
F7 code and beeping
in version 1 of your model, F7 requires the replacement of the EDC (electronic door control)
in later versions F7 requires the replacement of the EOC (electronic oven control)
Feb 01, 2009 | Frigidaire PLEF398AC Electric Kitchen...
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
GE Spectra JBP78 Electric Kitchen Range Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
