Question about Panasonic KX-FL511 Plain Paper Laser Fax
Feint Printing on one side & blank line down the middle
  • 68 Answers
Replace toner cartridge
Posted on Oct 06, 2009
Mfc 9880. printing clear 100%. problem with copying only. feint and blur copies, cant see 98% of doccument. i tried cleaning the scanner unit. i think i probably messed up sumthing..
Probably did! I found out the hard way on a HP All in One that all the remedies out there wouldn't make it print until I bought a new print head. This one would go through the motions of printing but I got blank paper in and blank paper out. You probably didn't mess it up it can do that itself. I would just get on the web and spring for a new head and be done with it. dhgill
Aug 24, 2011 | Office Equipment & Supplies
Hello, my problem is, when i print a copy I receive a blank line, it seems like the ink is finish or the middle of the ink is finish or don't have ink. don't know what to do I tried to clean the toners and...
If you are seeing a white line down the page in one or more areas, but it is printing fine in others it is most likely your toner or your drum. Try taking the toner cartridge out and shaking from side to side to evenly distribute the toner and break up any lumps that might have formed while it sat around. If that doesn't work take out your drum unit and look at the drum roller (don't touch it!) if you see lines or color differences on it then it might need to be replaced.
Aug 18, 2010 | HP LaserJet CP1515n Printer
My 3'' by 1'' label now prints in the middle to the right and cuts of info.
So the left side is blank ? Usually caused by an imbalance across the printhead. Check the toggle pressure on the left side. Each toggle has a dial on top for adjusting the down pressure. Probably less pressure on the left than the right. Quick test would be to use your finger to put some down pressure on the left side of the printhead while printing. If the print is there, you have your answer. If still no printing, then something else is happening.
Hope that helps !
Apr 28, 2010 | Zebra S4M Thermal Label Printer
Epson photo stylus R230 prints blank
I think you are in a hardware problem. In this situation you may try to set up a seringe in to a pipe that are in the back side of the printer.to find the pipe follow the mentioned procedure
1. (in off line position)open the scrue that are situated back side of a printer
2. push the cover and
3.find the plastic pipe into the blank space
4.Then set a sering in to the pipe and try to out ink by presure. 5/6 time.
if your printer stil not print, the mother bord of the printer should damage . change the mother bord and it will work fine.
Dec 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
Light lines down middle when printing black
try to clean the class of the machine, if its still there, this means the black drum is scratched since its fine with other colors, to test it very good open the document feeder(put it up) and hit start buttom(without putting anypaper on class), black paper will come out, check if the line there, if yeah, change the black drum.
let me know wat happen Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Apr 24, 2009 | Samsung CLX 3160fn All-In-One Printer
Blank printin on the right middle ohe paper
Toner may be low. Check the Toner level. You may have to clean the printer too if you have a new toner cartrage installed. You might also have a bad printer where its not able to fuse the toner in that area any more.
Apr 22, 2009 | HP Office Equipment & Supplies
The main bus on my behringer 2222 mixer has gone. nothing patched to the main bus comes up on the main vu meter, and only a feint distorted noise comes out of the headhones when the main bus is turned up...
please make all your fader down-all your rotary control at middle(12 oclock position)------all your pressed pushbuttons in up position--disconnect all inputs cables----use good new cables for outputs---bring a good mic and connect it to any channel and raise its fader up and main mix faders up and check if the problem solved check your cables and your pressed button if not better to contact a good service center.
Aug 17, 2008 | Audio Players & Recorders
My canon LBP 3200 printer is printing with a blanked out section about 8cm wide right down the middle of the page! Help Becky
This is usually the frst sign that the toner cartridge is getting low. Take the toner cartridge out and shake it side to side (not too violently) to loosen up the toner and so that a uniform amount can be used on the printing tasks. This should do it, but only temporarily because as I mentioned earlier...this is the first sign that the toner is running out.
Jul 07, 2008 | Office Equipment & Supplies
HP LaserJet 4000tn Printing a Black Line
Change the toner cartridge, refilling will not solve the problem.
May 29, 2008 | HP LaserJet 4000tn Printer
Blank Strip Down the Middle
My guess is the fuser needs to be replaced.
Apr 21, 2007 | Epson TM-T88III Thermal Printer
Panasonic KX-FL511 Plain Paper Laser Fax Logo
77 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
